@z11pronomax
you mean that i have to disconnect the hard drive or usb with film from the form and work in windows... you aren't serious
Yes, MOL3 recordings are done to be only compatible with MOL3, i'm not sure Kodi will open the files, even the .m3u8 file that is in the android recording folder inside hdd. So, you either connect your usb hdd to a computer and do the work, meaning, join files with ffpmpeg or whatever and get a mkv file of the entire recording or just record directly through LAN to a shared hdd in windows, then recording files are already there and do the join... Use your imagination!!
And don't tell me you don't know how to do it because there is thousands of youtube videos and tutorials in forums explaining how to do this stuff, instead tell me you're lazy and bought this box so everything is done for you...
Tbh i used to try to record with several other iptv players like tivimate and i find MOL3 much better, recordings are done without errors, recorded 7 matches this weekend and 6 of them were 100% free or errors, only one was fucked up because channel was with network error. That's what's needs to be solved, this random network errors that only happen on MOL3, meaning tivimate on other boxes are fine, same vpn though!! So this is a formuler or MOL3 issue...
And this network errors are completly weird, they come up in a channel, then you change to another and return to the same and it works again, other times when you're in the channel giving network error if you go to the catch-up menu you can see everything , even the live event, so portal is ok, server is ok, MOL3 is bugged!!
