Posts by MrZ
Wien I define a subtitle size and start a vod movie it still show standard size. Anyone else have this problem?
I have 500/100 fiber. And I dont use wifi crap.
I have thought about provider issue but I dont have these issues with same provider and tivimate.
Z8 with MOL2 and latest updates.
Have experienced this for a couple of months Now and have tried everything I can think of. Tried changing buffer, tried m3u instead of portal, factory reset.
Any idea of a solution?
Is there any way to change the subtitle size in Z7+?
I can change it in my Z8. -
It's the same with Z7+ and Mol 1.
Already tried that also. =(
I tested with dvb-subtitles also and its the same. Its not embedded teletext subtitles.
Now I noticed, when I change the size in settings, it doesn’t change in Mol2. The size in mol2 remain the same.
Have tested different settings but nothing fixed the problem.
Probably, have tested it on 2 providers and its the same on both.
how do i change the subtitles? Font? Size? -
The strange thing is that this started mayby 2 months ago. I havent seen it before that.
How do I get more then 1 row of apps?
How do I use this function? I press the yellow button but nothing happens.
Le plus grand centre commercial
rée quoi s'agit-il svp ?
Go to
Yes, if you use xtream editor.
Ok, to that i use the cursorbutton on the remote and use channel up/down to scroll up/down.
My solution was to use the version in ”Market”. If I use the version in Google Play Store I can’t move sideways.
Be able to set a delay of the teletext sutitles and for MOL to remember each channels subtitle
Yes. The dvb-subtitles is working nice.
Is it possible to delay the subtitles with mayby 2 seconds?
This is a feature that would great to have.
I dont have a android phone. Only an iOS phone.
Does anyone know how to scroll sideways in Netflix? I use channel up/down to scroll up/down but I can’t scroll sideways.
I respect that you had a tuff time in your private life but I have a question for you that I have sent to you in a pm.
If you have an answer, please give it to me or just say "i don't know"
When I use mytvonline the epg works 100%
I know what you mean, I just bought a MAG box instead.
Probably the same as this.....
It started working after a serie of reboot of the box -
What navigation issue are you facing?
You need to use the mouse cursor mode. Press the mouse cursor button on the RCU and use the d-pad and CH UP/DN buttons to scroll.
Alternatively you can connect a wired/wireless mouse to the USB port.
How do you scroll to the right past the window? the cursor stops at the edge of the screen.
Anyone else that have problem with navigating inside the Netflix app?
No I don’t have a ir remote window.
I have a Philips 55pus7600 -
I’ll fix it today monday. Do you want the URL in a PM?
At the moment Mytvonline doesn't support m3u-list.
But you can download other apps that can use a m3u-list, ex Kodi. -
Have tried that.....
I dont want to be annoying... I can live with this problem. -
Arion75 and SAM, have tried both your versions but it doesn’t work.
SAM: after I press the Philips remote the 2nd time I cant get the formuler remote to do the 3 flashes.
Arion75: with the source button the led doesn’t go to a constant glow. -
If you press the source button, nothing happens!!
This sounds just like the problem I have with my CI+ module for the swedish terrestrial channels
Just noticed one thing about the Swedish subtitles (dvb-subtitles). Sometimes they don’t appear. If it happens, I do like this.
1. Start epg, close epg.
2. Change to another channel, change it back.The subtitles works!
This is really strange. That doesn’t work for me on My Philips remote.
