This topic is not about synchronization. You can open another thread for that.
Posts by satcom
Opensubtitles.org stopped working.
It downloads the subtitle, but the only sentence you see is:
Become OpenSubtitles.org VIP member to get subtitles -> osdb.link/vip
Do more people have this?
I tried several series.
Cleaned up the subtitle cache
Log out log in.
Restarted the formuler.
Cleaned up the app cache.
Nothing helps.
My account is working.
Since the EPG issue is reported already 2 firmware updates passed by. None of it solved it.
Why are some posts getting deleted?
Since the EPG issue started in june, 2 firmware updates have passed by. None of them solved it yet.
The issue is clear that it is not a provider/portal cause.
Indeed, we can call it XCAPI EPG problem.
It all started 2 months ago.
EPG issues started 2 months ago for most of us.
Back from holiday. See that there is a new firmware update.
But it did not solve any of the EPG problem.
İ hope the developers will fix it soon, as it is not fun without EPG
İt could be that maybe some headers in certain EPG stream is not understand anymore after the last firmware upgrade on the Z11.
Why i am sure that it is firmware related, is because my parents have same provider and same Z11.
My provider proof to me that he has EPG with other customers.
İ mean that i pressed the Update EPG button. But it did not update. You can see when pressing that button, that the spinning next to the text XCAPİ is present real short. Like 0,5 second.
But when you press Refresh the channels then the spinning lasts for 20 seconds.
İt looks like the EPG refresh software part can not start up the refresh process.
Does anyone know when a new release will be released?
I installed iptv Smarters Pro on my laptop and the current program information is also visible.
I uninstalled mytv online and reinstalled it
But did not solve.
Only thing left is to wait for a new software release...
I just found out that on my phone the EPG is present.
So my conclusion would be then that my provider provides the EPG. And it is the formuler device which can not show it.
I think it started after the firmware upgrade of 2/3 weeks ago.
I have now v11.2.6 for the formuler z11 pro max
11.2.15 for the mytv online3
Bedankt Henkie
The main problem is that I don't see EPG at all. I would not mind if I could see only current EPG with XC.
I don't want to use MAC as it will limit my other devices.
I don't know, as i used it more for cloud shift to watch a program back.
Never needed it for the future upcoming programs.
And the EPG was handy to see the name of the current program.
I tried as an alternative a connection via IPTV Smarters Pro but also here no EPG.
Provider says that it is same protocol so it won't work there as well
Since couple of weeks I don't have EPG anymore.
According to my provider this because I am connected via XCAPI.
He says that it works fine with Stalker.
Is he right or does he not want to spend energy in solving my problem?
I tried everything, even reinstalled the portal. Update EPG, refresh, nothing helps.
It used to work well from February till May.. ( i bought the Formuler in February)
Thanks, but is this an expected behaviour of a box which is not the cheapest?
I am using this brand new box for 2 months.
Now i have to reinstall and set up all the accounts all over again.
The hard reset has solved the crash, but to me I would have liked to know what caused this problem.
Suddenly the streaming channels stopped working.
I decided to reboot the box
Now it does not start up anymore. It hangs at the Formuler logo with junping colored dots.
Why did this happen?
How to resolve it?
