Any input would be great thank you
Posts by Bluemoon
so iptv provider put me on M3U (which worked no problem on other devices) and on MOL3 Formuler z11pro it was skipping and buffering tried everything and it would not stop.
Moved over to MAC and boom works faultlessly.
Anybody else hade this issue
If not done, update to the firmware 11.2.1.
freezing on some content was resolved.
am on the latest firmware cheers dude , still little skips and stuff driving me bit mad now. Watching on old iptv app and it works great something is clearly wrong somewhere. not sure if this is a well know issue
spoken with my provider been with for 6 years and they're great. played stream on my old iptv app on a shield and no issues but still little issues with mol so still not sure hmm weird lol
Display More
most common to try:
1. Enable AFR in mol settings
2. Try streaming with out any accessories connected to the usb. also if using nas disable it as well as disable timeshift.
Also remove mem card.
3. Try with vpn off if on.
4. Ask provider to reset the connection. also power cycle the router.
5. Try ethernet if using wifi.
Thanks rabbit
mol what does that mean mate ?
Do you have this issue on all channels,if so its probably a provider issue and you can ask them to reset your line.
seems on only few channels going to get tonreset line thank you for your time 🙂
Haveing several stutters in jumps whilst streaming on iptv. am on BT 900 so speeds is no issue just wondering if anybody has these issues and what settings people have on there boxs ?
Brilliant thank you for your reply. Il get an SSD then
Hi new to the box just bought 2 for the house.
Can i record from my iptv if I plug in a hard drive?
Thank you for your time
