Thank you SAM,easy when you know how....like everything.This little mini s is more
appealing by the day.
Cheers
Posts by hybridkid
Hi SAM,looking forward to the future with this little box.Really like the mytvonline app,looks much
better than mag box.Zapping is very fast and all apps seem to work good.
About the background narrative,it is an audio stream with someone describing what is happening
on screen.I am not sure,but think it is for people with bad eyesight.0n E2 it can be changed to a
different audio stream using the audio button on remote.If you can receive astra 28.2E and have
a linux receiver,try some of the free to air channels and press the audio buton on remote,it
usually appears as NAR in audio [lexicon]settings[/lexicon].Not all channels have this setting available,only some.
I have only noticed this problem occasionally on bbc channels,not all broadcasts seem to be
affected either.It is not a big deal,but can be annoying when trying to watch something.
Cheers -
Thank you SAM,I can finally delete unwanted sat channels.I did not mention the CS word on earlier post,was only talking softcam,which is talked about on every sat forum under the sun,why so strict on here when we all know what these boxes are designed to do? So far, I am quite happy with
this box and realise that it is early days firmware wise.I have a couple of other small issues you
may be able to help with.
Is it possible to turn off subtitles on all satellite channels instead of having to do each channel
individually? Subtitles automatically appear on every sat channel.
Is it possible to turn off background narrative on some channels? so easy with E2.
Cheers -
Good support = product lives
Bad support = product dies -
Hi all,does anyone know if there is a way to delete an individual sat channel/s on the mini.So far I have
managed to delete all the channels 3 times while attempting to remove a single channel.Better not mention
which channels I am attempting to remove as it might upset admin here
.Also would appreciate some
info on alternative sources of knowledge on this box,in english,as all I can find seems to be in russian.
Cheers
