Search with the Green Button. If your provider has a proper epg you don't need game day.
absolutely
absolutely
Can i seee screeeeens
Just for my family members
Install Smarttube from Market
Where can i tell MOL to play trailers in Smarttube?
Omg, need screenshots ❤️
Happened again. And its not a vod Channel.
Hi Guys,
This message keeps popping up after a time watching.
1) im on Xcapi (not m3u)
2) i asked my Provider about this, and asked him if its wrong in his panel or something. Because actually these are no VOD Channels, these are real normal live tv channel. ![]()
What can i else check?
Return box please
try this or do a factory reset first.
https://support.formuler.tv/kb/article/229--manual-factory-reset-z-mini/
cheers and report back
thanks for clarification buddy
Yes ok. Thank you brother 😂😂😂 im not stupid
You cant read: i said: maybe its wrong copy paste from z11 pro max website.
But sam confirmed its same chipset newer revision. But there is nothing on the internet
but ok for now.
If formuler site has it wrong or mistakenly put RTD1319C instead of RTD1619 i understand and that's a big improvement and totally worthy of 190 EUR. Other than that...
Yes thats what i thought
Because i dont see any new revisions of 1319 like sam said
But lets see
Dear SAM can you bring light into the dark and tell us which chipset? Thanks ![]()
Very disappointing specs of the Z12 “ULTRA”. The same chipset CPU and GPU and internal memory need to process a heavier workload than on the Z11 Pro Max.
Lets wait for confirmation
Chipset is the same like z11 pro max?
I think thats a typo right?
EDIT: CPU and GPU and RAM are 100% identical to Z11 Pro Max:Realtek RTD1319C
Mali G57 MC1
4GB DDR4 2400MHz
Ok, ist that true? Oder not correct
? Usb tuner you have to buy seperately
Formuler is cookin
One thing i always see at MOL3 and here is the translation of Factory Reset in German
Formuler you write: Nutzerpreferenzen.
Its: Werkseinstellungen
and then: Auf Werkseinstellungen zurücksetzen? JA - NEIN .
Maybe you can change this in future releases ![]()
Nobody asked about Kodi, thanks for your input but this wasn't the resolution I'm looking for
Ok. No problem for me ![]()
It's an issue with the box, not the app I'm not switching to another app, I bought it! The file plays fine in VLC
i do get better results with playback with kodi (audio & video)
the plex app ist not the best out there!
same on Apple TV - Infuse plays plex content better than plex itself.
but first please look at the DM from Peter
of course we do ![]()
we all buy Z12 my friend ![]()
Lucky13 thanks for clarification ![]()
that was excatly what i said. just want to tell - that it makes sense
to TURN ON AFR.
but i understand people who dont care ![]()
Z-Mini has QMS (Quick Media Switching)
unfortunately my OLED is one Gen too old for it to test. But tried at my friends OLED. Insane.
Yes please. With the specific plugin. And try
cant live without AFR -
in Europe, i would set the box to
4K - 50hz
most (all) EU Channels are 50HZ (50fps)
when switching to US Channel then i should switch to 60FPS . what is correct. (and back to 50)
and of course movies / series are in 24HZ
i would NEVER watch one with 50 or 60..
This is complete WRONG SETTING!
Hi,it should work without problems,once you set up your box completely,internet connection etc,just unplug your device from power for a minute,connect power again,start page /loading should start and your IR remote is ready for use
But how he can connect the standard IR remote? He cant pair it.
So he cant setup up the box because he is stuck at the first screen!
Can you pair your mobile to your Sonos setup?
This should work on iOS easily
Menu (three stripes button)
Content Manager
Data Sync
Auto Update
afaik in my head right now
you can set a autoupdate every day to a specific time you want.
try the KODI-Build with App "PM4K for PLEX"
and report back please
