Posts by Balkanboy
first, that problem has not been there for a few weeks now, everything is going well at the moment, watching TV also works well
I don't use a VPN here in the Netherlands and have no problems. I tried it once but saw no difference, so I have no idea what is the point of it.
myn close too mol
Quote
Yesterday the VOD disappeared suddenly out of the menu only saw live TV and live radio had to restart the box 2x
Its server problem.
They put the live channel(s) at vod.
Mail provider till they fix it.
Then should it work again.
That's completely correct, I sent a WhatsApp message, problem has been solved
Hello, I always watch Bulgarian TV, never have any problems, but now it says that it is VoD and that I have to activate VoD player, but that does not work, other countries, for example England or Dutch, work, if I activate my other server that also has Bulgarian TV, it works. Yes, this is a problem with the server. I tried to search on the forum, but there is little information about the Z11 pro. I have also reset it to factory settings.
You guys are all TOP
, THANK YOU
!!As for me the problem persists, grrr, so they didn't solve anything, will AGAIN contact the other provider.
And the strange thing with me is that it only happens on Belgium channels NOT on channels from the Netherlands.
strange I bought the box at the beginning of May I have not experienced it so extreme, I think it has something to do with the server only
Buffer and dns☺️
how and what exactly did you set up then
totally agree they should first make it stable and then improve other things
I personally found this issue presents from the provider stream
Lucky has given great info.
and what did you change
hmmm then I can knock it off outside the Epg which does not have every channel I hardly experience any problems and if something fails it is solved by the server and usually within a few hours I have not experienced any failures for the last 2 months
Again like clockwork, some channels go "network error" at 8PM and lasts until 0AM...I have no issues on tivimate, iptv smarters, even kodi, same channel works on those apps at 8PM, but not on MOL3...Maybe API problem?
hello what do you mean by this then ... Maybe API problem? what does API mean
hello as known I it is also known
Last night i've got a lot of network errors on both xc and stalker portals, but only on some channels, meaning portal was working fine on some channels and giving network error on other channels... After 00h00 AM things got fine.
I will test it again tonight, but i will change vpn country IP to see if it's related...
Could it be that the server is overloaded?
okay learned something new
Which Protocol is in use? XC APi, Stalker or M3U?
is that difference then XC APor something else
I think it's from the server I had it at the time too, I don't have it on other servers I think it's some kind of watermark
Not big issues with beta update, but from time to time, as in tonight I powered on the Z11 Pro and it was sitting in the Home Screen. Another weird issues is, when I click on MOL3 it takes about a minute of the the blue wheel circling for the stream to come up. Never had this issue before and never had it with my GTV..
I haven't even done the ubeta update, but sometimes when I turn it on I do indeed also have the start screen and I have to turn on mole
I removed it anyway, the reason is that a server I use blocked it, on another server it worked but still got error messages so really see no difference with or without VPN thanks for your answers here to my question
Have a trial of Nord vpn now it works on another server that what I like to watch apparently has problems with the connection at the moment, but which country is best to put on the Netherlands or another country, this trial period lasts 7 days to test and then you can, for example, choose to choose longer
had a trial version installed but then it doesn't work at all what am I doing wrong
Yes,you can buy a Nord vpn for a 1 month period,and decide after trying it out,to go for a 1 year or 2 year plan.
Its not cheap but works well and there is a good support team available.
but will that solve the error code then
can you only purchase vpn for a year and not per month, because I would like to know first if this works well because I often get error 521
I have the same problem, often have to go to vod 2 or 3 times then he will get it
but at the moment the server is running well, almost never any problems, but I don't understand it because 1 says to use it, the other says it is not necessary
unfortunately the thread where I asked something is closed is there also a free vpn or does that not work what is your recommendation
In first line to secure you and your connection! Second to sort some errors in routing and others, isp blocks of iptv, provider blocks from isp, etc. There are many reasons to use it. Adrilang explained this very well in his post. There is time or will come, where each user must use VPN for IPTV. ISP`s and some other institutions work on it to throttle , block where they can to save data throughput.
If some Provider doesn`t allow user VPN and the connection fails, then it`s only because this provider want real data from his user to control ip, region, country etc.
I recommend also to each user, to read so much as possible about VPN and to use it if possible.
I don't use a VPN, but is that really necessary?
