Hi everybody, I found this item on amazon.
The IR extension cable is the same: it's working! Hope it helps.
Thanks for your help!
Ok, I have more Formulers in that area but I think it will be paired with the one i want.
Over all: the fact is that I already have a cable extension setup.
First step: I'm buying the cable i linked. Hope that's enough
Thank you for the alternative
That could be a beautiful workaround.. however the Formuler is technically in another room
Thank you for the idea!
henkie: thanks for your info.. I have already searched their site and i didn't find it: so i wrote them. If they won't reply I will call them!
BTW: I agree!!!! Let's see Inter on the 10th..
Hi, I have a FORMULER Z11 Pro Max and I need another IR Extension cable.
I have researched this forum and the web but i didn't find it, i also opened a ticket but they can't help me: can anyone give me a link or a e-mail contact to buy it?
If there is no way to have "exactly" that, a compatible commercial one is fine too.
Thank you in advance!
