Posts by retep102
    i have bought a z11 promax and have decided to install tivimate,if tivimate is used on nvidia shield it can only record 4gb because of fat32 has to be used.
    With tivimate on formuler z11 its possible to record to internal memory unlike with mytvonline3,does this mean that i will be able to record files without 4gb limit,as the formatting is likely ntfs?
    hi for the first time i have accessed the app for programming the remote for formuler z10 pro, i wanted to find a shortcut to connextions,but i cant find connextions in the shortcut menu, why not?
    to have that option should be a must , a fully obvious choice? Why isnt that choice available? Can it be made?
    Peter
    hi i did a facttory reset in from the menu ,and afterward i installed mol2 ,but now i cant connect to myiptv ,i only get the radio stations,it works fine on an old box?
    did i do something wrong,is it a necessity to reset hardware first by using a clip in the infrared hole and first then do resetting in the menus?
    peter
    hi i have a problem . by couriosity yesterday i doubble tapped the home button on the remote. and a screen popped up with 2 pics and a red field in the lower corner saying "clear all"(in danish "ryd alt".which i trnslate into "clear all"), but i didnt know what it meant so i used backbutton on remote, but now it pops up now and then as i start the box? I dont like it as i probably cant prevent a scheduled recording from happening next time it pops up at startup? What can i do and what does it mean?
    peter
