There is no setup wizard so I’m having to unhide group one at a time
Posts by ryanward_94
I have the full sonos immersive setup with z12
Yes only Kodi can play the truehd as external player I’ve found but then I loose the ability of everything being tracked
Has anyone been able to get Dolby truehd to work using the internal player for mytvonline3? It works using Kodi as an external player for VOD however plays as stereo pcm using internal player
Thinking about getting the Formuler Z12 Ultra, has anyone tested out the audio pass through to confirm if it passes Dolby truehd etc?
Will this support all audio passthrough?
Hello there,
Is there any tuners which are compatible with the formuler z11 pro max?
I mean when channels have been favourited can you rearrange within the folder?
Is it possible to rearrange the channels in a favourite group?
