Got the Z11 Pro Max connected to my NAS via SMB, which isn't my preference, but still can't set Tivimate to use a USB stick for recordings.
Posts by markn62
Trying to store recordings to external USB drive. Can’t because there is some sort of hardware lock on the Formuler that doesn’t give a “System Picker” choice in the Tivimate app’s “setup, other…” Can’t record to SMB network storage for the same reason apparently. Anyone encounter this?
Made many unsuccessful attempts to log into Gmail, both through the Formuler settings and the Play store. This while showing active internet connection. A few hours later I came back to the device & to my suprise it showed successful login & I was able to dl an app. Got me…
With NordVpn I had various issues primarily bandwidth ranging from 5mbps to 150mbps. After changing my subscription from dynamic to a fixed IP its always +100mbps & reconnect issues reduced substantially to ~1/wk for a minute or so. Before discovering this, I tried ExpressVPN, and it would not work with my router no matter how much Support tried to make it work. After two weeks I just gave up and canceled it.
Just got a Z11 Pro and doing setup. How do I satisfy the gmail login captcha with the supplied IR remote? Doesn't highlight the choices.
