Thank You Sam. I will make a test.
Posts by MrMoLoZ
I dont have the problem with other models. I only have the problem with NANO Z... Unknown… Plz lets get in contact if you have a solution.
Dear formuler support.
This is my 4th Z Nano and the issue is that only with the Nano's the server is reconnecting if I switch with my channels. Or if I make the switch in live/vod. Is this problem reporten earlier? I cant imagine that Iam the first one with this problem.
Maybe you know a solution.
Thx
Hello dear,
After the new update my F Z+ is not comming out of standby mode. Nothing helps. Is there anything I can do ? Its like not reacting on nothing.
Thx a lot
Hi all.. Is this problem also known with the formuler Z+ ? I cant get mine back from standby. Only what I see is standby and doesnt reacting on anything. Can I specially do something for the Z+ ?
THankss all
