I have a Z10 pro max for over 3 years now which is amazing never had any problems with it works perfectly bulletproof reliable.I set the screen resolution to 720p at the beginning..i have an old lcd tv at 1080i..i prefer the progressive display but since i don’t know when and which update its only Auto-1080i or 480p..the 720p disappeared..was it done on purpose?
Posts by Nicholas514
Thanks for the reply ill give it a try right now
Hi administrator on the Z10 pro max some channels when watching a movie scenes repeat itsef twice like the cat in the matrix a glitch sometimes just once others 2-3 times.A fix on the loop would be nice on the next update.Thank you
Timeshift and recording works perfectly fine on Z10 pro max but on the Z11 pro max recording works fine but timeshift works when the usb flash drive (Lexar P30) is freshly formated (Ntfs) then stop after some time and the progress bar stay at zero on the lef on every channels
