Posts by Zibupiu
    Also check your channel in favorites, if you see channel with special name like text or symbol or numbers, delete them !
    Sometimes when provider delete some channel, it crash Mytvonline when it try to acces them in favorites :winking_face:
    You mean backup from box 1 to restore on boxes,2,3,4? Sorry but its not possible, only restore on same box where was made backup.
    Hi SAM,
    Is there a way to get the password of the (compressed) backup file molxyz_xxxxxxxxxxxxx ?
    I can see the 4 JSON files in it and I only want to get the favorites to copy them to my another Z11 Pro Max.
    Favorites are so tiring to do with MOL3 :frowning_face:
    Thanks a lot for your answer.
    Hello
    Mytvonline3 can't load on z11 pro max.The main screen starts for 2-3 sec and goes back to the mytvonline3 icon again.In the evening I watched it normally but in the morning when I started it there was an error with mytvonline3. Is anyone where had the same issues and find any solution? Thanks in advance
    I had the same issue last week, for me it was a problem of channel that my provider change or delete...
    The only thing I could do to prevent the crash of MOL3 was to press a multiple times the "men" button, the one with the 3 lines.
    There I could disable my provider via the menu, and MOL3 stop to crash.
    I saw, in my favorite, al lot of channels with only an address, no names...
    I could not use the backup files I made because the favorite where in it, I simply delete all data for MOL3 in Android app and then start from 0 in MOL3.
    No pbl till then :winking_face:
    Quiet simple to know : download the epg xml of your provider :winking_face:
    "http://address.com:port/xmltv.php?username=login&password=pass"
    Could be a large file, if to large for your browser, try via PowerShell :
    wget "http://address.com:port/xmltv.php?username=login&password=pass" -outfile "c:\folder\filename.xml"
    And then check it with a xml viewer, you will be disapointed to see that sometimes you only receive 2 days in the future :winking_face:
    Cheers,
    Zibu
