Happens all the time.
Logs just sent.
Track # 00000018FF80F
Logs just sent.
Just did some more testing and loaded VLC Player onto the Z10 to try playing the recordings just to eliminate the player being the issue.
What I found was that the one hour recording was actually broken down into 2 .TS files. The .M3U8 file is only reading the first file.
If I play each .TS file, I get the full hour.
Don't know if this is a known problem or if there is a fix but at least I have a little more to dig into.
recording on the z10 did the same for me.
The z11 seems better in that aspect but it too has problems. These formulers are nice and powerful and would be a homerun if they could iron out all these bugs
That's strange how others are able to record properly. I wonder if all Z10s have this problem.
Gotta keep the wife happy and need to find an option that allows her to record, do you know if the Z11 has this problem or is it too a hit or miss?
Hi there,
I'm new to IPtv and hoping someone can help with my recording problem.
I'm trying to figure out why my recordings show they all completed normally but when I select them to play, they take a bit of time to load and when they do start playing it's not the full length of time that should have recorded. A one hour recording might only play 30 to 40 minutes.
I've tested a couple of thumb drives, tried formatted as fat32 and ntfs, tried formatting from Windows and rufus and from the Z10 box.
Tried recording on a live show and scheduling a show later in the day.
Tried leaving the Z10 on and on standby.
I've watched the recording start and stop on the scheduled times but when selecting the video to watch, the time recorded is less than what was programmed.
Nothing I've done seems to give me a complete recording.
Is there something I'm missing or should try testing?
