There is also one more waiting here.
Posts by ffonseca
Hi guys,
Timeshift bug. There is no return from pause.
Usually it stuck and disappears the image and/or only sound continues.
Firm v2.8.49 / IPTV v1.9.55 -
Hi man!
You go to settings/Android / Apps / Mytvonline and choose unistall, or just enter to the Market and select mytvonline / unistall.
To install do the same on the Market, download and install
Hi Redrooster,
You don't need to separate, just fill direct.
Commercials appearing on my tv online every now and then. Someone else have this problem and knows how to fix it? ...
Hi guy,
Try to see if you have any free app installed, they are suspect too.
Hello!
My question is if I need to regist, the MAC adress "from" MyTvOnline to get the connection.
Thank you.
Hi Guy,
A portal url is enough. You go to Menu/ Portals / +Edit Portal / Edit / fill in the fields and don't forget to chek "Login Required".
That's all -
Terrarium TV shutting down
“It has always been a great pleasure to work on this project. However, it is time to say goodbye. I am going to shut down Terrarium TV, forever. I know this day will come eventually. I know it would be hard to let go. But it is really time for me to move on to other projects.”
August update
Firmware Version:
Fomuler Z/Prime/Plus/Nano : 2.8.22
Formuler Z7+/Zx : 1.2.34
FIX: Z7+/Zx Stuck in standby mode
FIX: Market > Certain apps not showing in custom markets
FIX: Launcher icons not appearing after reboot
Added discrete Power ON & Power OFF keycodes
Custom Android hostname/device name supported. Change from the system menu
Market shortcut can be deleted from the homescreen
FIX: Installer Mode > SYSPIN issue
FIX: Installer Mode > Langauge preset not working
FIX: Installer Mode > Power mode preference issue
DRIVER: Add Tenda U12 USB WiFi adapter support
Android 7 > Android Security Patch Level : April 2018
General performance enhancements, UI improvements, and bug fixes
Improved Lithuanian language translation
MYTVONLINE Version: 1.9.48 (BETA)
Teletext Subtitles supported
Manual EPG time offset. Access from the Settings menu
Xtream-Codes API portals > TV Series section supported
VOD > Continuous play option added. Press the Green hotkey to toggle
M3U > All tracks from VOD-only m3u list are parsed and used - regardless of stream file extension
M3U > Compressed xmltv EPG archives supported (.gz or .zip)
Automatically hide empty groups/categories
Added stream codec details. View from the detailed information popup window
TV Series Shortcut. Press and hold the VOD button on the remote
Remember last selected subtitle preference per channel
Improved channel icon caching
Improved EPG download performance
FIX: EPG description not displayed when using M3U + XMLTV EPG
FIX: Black subtitle font when only 1 subtitle track is available
FIX: RCU VOD hotkey while in Classic Channel list
To change you must use the alphanumeric keyboard
Sure, enter Settings (gear) / Ethernet / option Manual / go to 1º DNS and change it.
Great man,
I can understand you but my english is very bad, i forgot to say that was to enter code in "user market". Well, anyway try 9865 too, but forget yellow button.
b.regards -
In the market, go to the first icon at last line and insert the code 0852.
I did 0852, took a little while but logged.
Yours is old, update to v2.8.14, and s/w revision r14397.
Sorry Aaj,
I'm not a good teacher, but vpn It's a way to protect your network connection and you'll understand better if take a look here... https://whatismyipaddress.com/vpn
Ttry to put a new mytvonline link on start screen and open it, then you will see service option, after enter Menu. -
Try to use a VPN
Enter the MOL, menu key, service option, edit list and enter the nickname, url and inform the provider the MAC address.
Menu / Setup / Clear EPG
Versucht, einen Werksreset auf Setup / System durchzuführen
Thanks it work.
Do u know any that come with keyboard. Really want it to copy my links like m3u r when I need to type something.
Just tap the screen and will appear keyboard to type or paste the link copied.
It has great features and works great if you have a good iptv service.
Which box are you using? model#
It'is a provider box. Formuler z+ model.
Settings-> Update -> red button for "Beta Test SW".
But it's like I say in the post above, here for me, does not appear update 1.9.42, even pressing the red key as you said.
Please, how can I get Beta 1.9.42?
I updated today, the new version is 1.9.42.
Where this? here does not appear nor press the red button
It was a emergency patch for a very specific portal problem, nothing big of interest.
It may be that improve the initial connection with the portal. I think i'm go to try
Hi SAM, hi All,
After beta version has been instaled the inicial bar is very slow, some times goes to menu settings and msg appears asking to see internet connections, but is everything ok with the provider. So, can I downgrade to v1.9.36? If yes, how can I do that? -
Try it, Air Sync Remote-z
Hi SAM,
After the Firmware and Mytvonline upgrade is completed, which of the procedures is required, the software reset or factory reset?
