How to Download Online Subtitles and Use Them in MOL2
To download online subtitles, first search for subtitles that match the exact name and language of your video. Most subtitle files are downloaded in SRT or ASS format. Save the subtitle file to a location you can easily access.
After downloading, check that the subtitle file name matches the video file name. This helps the media player or application recognize the subtitles automatically. If the names do not match, rename the subtitle file accordingly.
Before importing subtitles into MOL2, confirm that the file format is supported. If needed, convert the subtitle file using a subtitle editor or converter.
Now open MOL2 and load your video. Use the subtitle option inside MOL2 to browse and select the downloaded subtitle file. Once selected, adjust timing or language settings if required.
Following these steps allows you to download online subtitles and use them correctly in MOL2 without issues.
