- HOTKEY PORTALS FOR SEAMLESS SWITCHING. The ability to hotkey directly to Content Sources for fast and easy portal switching. Because I have 2 Stalker portals added by the same Provider, I can only have one active at a time and can't take advantage of MOL3's new feature of running them both actively. It is very tedious and many button clicks to swap back and forth, and can be confusing more many older, or less tech savvy individuals.
- Option to remove Live, VOD, or Tv Series buttons from menu on respective portals. I have 2 separate portals from the same Provider, one for Live TV, and one for VOD/Series, both Stalker protocol. Interestingly, if I hide all the 24/7 groups included on the Live TV section of the VOD portal, the play screen will default to an all black screen with the side menu always open, and Live TV button has been automatically removed. However, the Live TV portal has no VOD or TV Series groups, yet both options still exist on the side menu when in the Live TV Portal. Being able to remove those two options manually will reduce a lot of confusion for people like my 74 year old father about what portal he is in and what is available.
- VERY POWERFUL FEATURE "Similar to" option that can be selected when previewing a Movie/Show Title. Example, you are clicking through your history, and find a movie you enjoyed, being able to click that title, and then select "Similar Movies" from the preview menu.
- Option to re-order the MOL3 menu list
- Move the universal search button in VOD/TV series from the top right corner inside a group to the top of the sidebar outside of groups, above favorites/newly added/history
- Create multiple Favorites lists for VOD/TV Series in Content Manager. I have a ton of Series in my favorites, being able to separate them by genre/type would be incredibly useful
- Option to sort favorites, so we can move most viewed/liked to the front of the list manually
- Delete all, or group delete history. Anything so that we don't have to delete them one at a time.
- Auto hide groups that have nothing in them
- Filter options for favorites folder(s)
- Predictive real time search results, eliminating the need to type out entire titles
- Search VOD/TV Series by actor
- Showing Favorites lists on the home screen for Live, VOD, and TV series even if they are split between two Stalker Portals. As of now it will only show the one that corresponds with whichever portal i was connected to when I exited to the main menu
- Option to schedule routine clearing the cache same as content refresh/hotkey clear cache
