I have a number of Formuler boxes, Z8, Z8 Pro, and the GTV. I'm sure this issue has been reported before but I can't find the thread for it.. I have network storage set up on all of them for recording and timeshift. The Z8 and Z8 Pro work fine, but if I leave the network storage mounted on the GTV when asleep, and then turn it on, MOL2 will just hang when it is opened. Then, if I disconnect and reconnect the same network share, MOL2 opens just fine. If I set the box to "power off" every time then it also seems to correct the issue, but I would prefer not to power off every time, and it makes sleep useless.... Is there a fix in the works for this issue? Thank you...
Posts by Likkonen
I would like to request that when displaying either style EPG, or Info Button etc on screen in MOL2 where it shows the Group & channel info in top left, could you please add the Portal connection name next to it as well. At present, you have to go back to Connections to see which portal is connected.
Thanks..
Display More
The speedtest app is not a comprehensive or definitive test for network performance.
Results can vary wildly depending on a lot of external factors.
Get more accurate results by using a local network performance testing app.
Install this app on your Formuler:
https://play.google.com/store/apps/det…eedtester&hl=en
Install the local test server on your PC:
https://bitbucket.org/pzolee/tcpserver/downloads/
Post your results as a screenshot like below:
My results: Formuler Z7+
Down: 95Mbit/s
Up: 99Mbit/s
I set this up on my laptop and from the Formuler z7+ it detects the server just fine... I have also enabled the ports in the firewall, and also tried disabling the firewall completely when testing, but I keep getting a connect time out when I click the start button.. In the Warnings section, it says No problems found. The network is fine... not sure what to do from here... any ideas?? thanx..
I'm fairly new to the Formuler z7+, and just did the latest firmware and mytvonline updates. When I check the MyTvOnline version# in the Android App Info, it is showing as v1.09.06-r1443. instead of v1.9.6 as is stated in the update info. It's probably the correct version, but I would appreciate if someone could confirm this for me..
thanks
