quinnr58 I had the same problem as you, to solve it I simply deleted the GTV BT3 from the Bluetooth clients in the settings and added it again.
Posts by Choubs
Chrille I had the same issue this week on my Z11 and managed to fix it by uninstalling the update and then restarting the app.
ericko777 You must send the MAC address of your Z11 to your provider so that they can modify your subscription and connect you to XCAPI on your Z10.
Hello everyone,
I found the solution. :
- Go to Settings > Apps ;
- Disable the “Google Play Store” app ;
- Restart the box ;
- Enable the “Google Play Store” app ;
It worked perfectly for me, I no longer have twice "Google Play Store" in the “Apps” tab
Hello everyone,
I notice today that the “Google Play Store” app appears twice in the “Apps” tab
However, in Settings > Applications it only appears once
Have any of you ever had this happen ?
Thanks.
In the case of my supplier, I send him a message before I go on holiday telling him my destination so that he can change the country of residence of my subscription.
Ferdinand When you use Wi-Fi in Europe, your IP address is European unlike with 5G where your IP address remains in your country of residence.
I'm almost certain that your IPTV provider doesn't allow IP addresses outside your country of residence.
Are you experiencing Accessibility services issues on your Z11 Promax BT1 device?
In your previous message, you mentioned 14 bugs and now you're talking about issues with accessibility services. This is still too vague for the community to be able to help you.
Formuler boxes are designed and created for IPTV and the MoL3 application is undoubtedly the best on the market. If you want to geek out, you might want to consider a different box.
They constantly release TV box models to make money, and they put them up for sale without testing or reviewing them. You've been searching for solutions on this forum for months, even years. I use a Z11 Pro Max, and this device has 14 bugs. Who will fix these bugs?
I also have a Z11 Pro Max BT1 and I don't have any bugs.
There's a saying that the problem is often between the chair and the keyboard
Phaze1105 All equipment comes with a manufacturer's warranty, contact your dealer for more information.
What is the point of the weather app for IPTV? ?
Phaze1105 You can try to reproduce the issue with the MyTvOnline+ app on Android or iOS.
This will help you determine whether it is a hardware issue with your Z11 or a problem with your IPTV provider.
shiloh You must contact your dealer directly, Formuler doesn't sell directly to consumers.
cragg88 I have the same issue.
Mine's coming in a few hours. Worried now. It better support dolby vision and atmos in plex or it's going back.
I look forward to hearing your feedback because that's exactly what I'd like to know (especially with the .mkv container)
Tarumar I live in Europe and I confirm that the 24-hour format is present on the Formuler Z11 Pro Max.
Settings > Device Preferences > Date & Time > Use 24-hour format
