Posts by ICEMAN72
    and We are back om the same problem! It worked a couple of times going into a VOD trailer, showing it on Youtube...Now we are back on looking at a trailer and it does not go back into MOL3 it is stuck in Youtube...If you force to close MOL3 it starts up with only sound...it takes a reboot/restart of Z12 for MOL3 to work again. Accept for trailers...
    Is it a bug? Does anyone else have this issue?! It doesn't do this on my 11 Pro MAX.
    Thanks for the qiuck feedback...
    It turns out MOL3 suddenly appeared for update after 2 restarts and now the issue with Youtube is solved for some reason :smiling_face:
    Never used SmartTube so I don't know how good that one is in this region...will give it a try!
    I had problems with Z12 MOL3 when looking at a trailer it did not go back from Youtube to MOL3 it got stuck. So finally I did a factory reset as I could not see the problem at friends Z12...Now I cannot find MOL3 in apps or Market place? How to I get it?!
    I have recently noticed that MyOnline 3 all of a sudden restarts by itself when searching in Series, Starting a movie... it happens more frequently (once a day) now. Is there a fix? It does not happen with my 11 Pro Max just with new 12 Ultra
