Display MoreI only say afr can be used with or without qms.
But with older models i didnt like it that 2 seconds black screen so i turned it off.
Only for vod and series i had it on.
With my z12 the afr is on and no more 2 seconds black screen so im very happy.
That the shield of you had no problems with switching, i cant answer that. This is a formuler forum and i don't know anything about the shield. maby an other user have the answer you want.
Have a nice day👌🏻😃
In your last reply you wrote: "Beware that your tv must support qms. If not, turn of AFR"
I didn't understand that this meant that afr can be used with or without qms.
But I do understand that this is a formuler forum, it's even named that way. The only reason I mentioned an other brand was that when something works on an other (older product) I guessed it would work on an Z12 wich is an outstanding product. And to illustrate that the lack of qms on the TV can't be the only reason why the afr doesn't work for me. I suppose it will work eventually, but I didn't figure out how, and that's why I asked for help. But thanks anyway ![]()
