Tried that but still the same unfortunately. I might try factory reset the box whenever I have time ![]()
Posts by Lebowski
I did clear cache etc. I'll try doing the back up and re-install, thanks.
Display More
I don't know what you actually mean in your message. But on desktop if you go to cogwheel right corner there you find launcher settings. There can you setup mytvonline as startup app.
And in history and favorites settings you can switch the live, vod and series on for the desktop.
I didn't. It's for me to much on the screen.
But that it goes to live when you watch a serie i can't figure out.
Did you try it with other serie to test?
Basically i have no app in the launcher set to auto start.
If I open the MOL3 app from the app drawer it loads the last live channel which is fine
If I scroll down to "history" of TV shows, click an episode and click play, it starts playing in MOL3 but then after 5 seconds or so it launches the last live tv channel played. I then have to go back into TV series and click play again.
Recently bought a z12 ultra, loving the box, I like the home screen shortcuts to VOD and MOL3 seems a sold app all round.
The only issue I have is I have set my homescreen to show the viewing history for TV series & Movies, but if I launch a TV series from here it starts playing in MOL3 then a few seconds later it jumps straight to live, so then I have to exit live and re-launch the series again, quite annoying. My TV is set to start over in the player settings and in the launcher there is no app set to launch at start up. Just wondered if anyone knew why it does this and how to stop it?
Cheers.
