Greetings to one & all, How often do you get software/firmware updates from the Formuler team re Z12 Ultra Thanks J
Posts by JohnD23
Hi How did you reinstall the app ? I can't find the apk anywhere and my MOL3 is giving me all sorts of issues there is nothing on Play or Market and a Google search reveals nothing Thanks J
I can't connect to anything on the mytvonline3 app I'm using a z12 ultra and only had it for a couple of days !! I add all the server details URL user name password etc but every connection is coming back with errors, I'm checking them on tivimate and they load no problem, For instance I can't add a m.a.c address for a "stalker" set up as the box is greyed out and can't be edited I wanted to uninstall the app to see if a clean build would sort the issue but I can't seem to find where to reinstall it, I thought the app would be on the Formuler "market" app but it isn't !! I'm using Surfshark VPN tried it both on and off to no avail !!
Going through a steep learning curve after relegating the Fire TV cube to the bedroom would really appreciate some advice Thanks J
