Posts by Randompig
    Network -> your ssid -> IP- > execute dhcp. After that restart your box and router once, first router and when online the box. test again.
    Formuler doesn`t get official certification and you can imagine how the cheaper Boxes get they own (cracked keys) -> and this is no option for Formuler.
    So I’m pressing ip settings which is already dhcp, pressing dhcp again it says saved successfully then restart box and router? Just done that but double checking as nothing to say execute dhcp
    Just got the z12 this week, worked fine for few days but then few days ago it started having a popup on the top right that says WiFi is not connected
    It reconnects almost instantly so the content doesn’t stop playing, but the popup is very annoying
    It’s the only device that does this, phones, laptop, firestick and the cheaper box I had before never did this
    Ethernet is not an option, but like I said it worked perfect first few days
    Second issue is Netflix doesn’t work, though I’m not expecting a fix to this just a bit of a letdown on a box that’s so expensive when the cheaper ones run it fine
