Posts by lobb
    I got the Info that Seller is the one who have to clear this Issue and he know very well what to do. Why this seller makes from this return so big issue is unclear for me, he need just to contact the distri from where he buy the boxes.
    Do you have an official source that confirms this information?
    If they persist in their nonsense, I believe I will need to involve my lawyer to resolve this situation.
    Thanks again. I’ve understood the lesson.
    The second Z12 device I bought is working properly and I like it a lot.
    Now, the point of this post is to figure out how to get a response from the seller, who is making me wait unnecessarily by claiming that I “damaged” the device, even though they have the option to refund me or send me a similar device.
    forwarded your request to Formuler.
    Btw. not nice move from your seller to hold you so long.
    Thank you very much, Sam!
    I really don't understand their attitude at all. I clearly explained the situation to them. I also made it clear that I don’t want a refund (you never know, that might slow down the process), but that I would like to receive another product instead.
    They’re just leaving me waiting like an idiot, telling me they are supposedly waiting for an analysis from Formuler.
    Sam, I can provide anything needed to prove my case.
    Thank again !
    Hi all,
    Very recently, I purchased a Formuler Z12 Ultra from an official seller in Spain. After receiving it, I unfortunately performed the installation with my VPN activated. My Formuler got stuck.
    I sent it back to the seller so they could, in theory, send me a replacement. They told me they would send me one as soon as they received the damaged one. I made sure to send the package within 24 hours.
    Upon receiving the package, the story changed, and they told me they needed to wait for a return from Formuler. Time passes, and nothing happens.
    I requested a refund (which is legal within the 14-day limit), but the seller explained that I had 'damaged' the device, even though no instructions in the manual indicated that the first installation shouldn’t be done with a VPN activated in a geographical location different from the one the box is intended for.
    meanwhile, I bought another Formuler Z12 Ultra from a different seller and am happy with the device :grinning_squinting_face:
    In the end, What should I tell the seller to accelerate this situation?
    Is there a Formuler representative on the forum who can help me resolve this issue?
    L.
    300 per Group but you can create many of them if needed.
    Thanks, admin !
    If I understood correctly, I can create up to 300 groups in “Favorites”. Is that correct?!
    #10
    Cher ami,
    après quelques heures d'utilisation, l'application n'est pas si mal. La réactivité est vraiment bonne et les commandes sont intuitives. Je vais devoir configurer mes favoris pour accéder rapidement à mes chaînes habituelles.
    Est-il vrai que le nombre de groupes dans les « favoris » est limité ?
    Il me semble avoir lu cela dans l'un des milliers de messages que j'ai consultés lors de mes recherches sur la Z12.
    You can create 10 groups for your favorites—but you can use a single group, naming it, for example: Spain-Portugal, and include 150 Spanish channels + 150 Portuguese channels.
    Très bon français !
    It seems he has already read that information. Who is right?
    Dear friend,
    After a few hours of use, the app isn't that bad. The responsiveness is really nice. The commands are intuitive. I’ll need to set up my favorites in order to have quick access to my usual channels.
    Is it true that there’s a limited number of groups in 'favorites'?
    I think I read that in one of the thousands of posts I went through while researching the Z12.
    In the end, everything went well. The Z12 Ultra is really smooth.
    Formuler should mention that the setup needs to be done without a VPN enabled to avoid geo-blocking.
    That would have saved me this delay.
    Otherwise, I’m not completely convinced by MyTVOnline 3. Is there a way to see the full list of channels without having to go through all the groups?
    Thanks again :smiling_face:
    Like Lucky wrote, initial or first setup always without VPN otherwise is Geoblock possible, when setup is done and Box configured (back to menu) than you can install VPN on Box and use.
    Thanks, admin (y) !
    I finally received it. I’ve just completed the various system updates after connecting it to my ISP router (so, no VPN whatsoever).
    Everything seems to be going well 🙂.
    Thank you for the detailed response.
    I already have a clear idea of how to use the Aircove. For safety, I will connect the Z12 Ultra directly to my ISP router.
    I'll give you feedback later this evening after setting up the Z12 Ultra, which should arrive in a few minutes!
    First setup with ip in europe ofcourse... (without vpn! Turn off vpn in router) Otherwise if you start box with an usa ip you will cause the problem again. Don't!
    After complete setup and updated firmware...
    ...then put on your vpn to usa and should be work.
    Thank you very much for your quick response.
    I’m glad to learn that the VPN is not a problem for the daily use of the device.
    In a few hours, I will receive a new device. I will make sure to configure it without the VPN enabled.
    One last question: how will I know that the device is completely configured and that from that moment on I can safely use my VPN with a US IP without causing this problem again?
    Is there any trick I should know to avoid another surprise ? :grinning_face_with_smiling_eyes:
    Last week I was looking for a TV box and decided to purchase the Formuler Z12 Ultra. I live in Spain, so I received the European version of the device.
    After receiving it and completing the initial setup, I discovered that the device had been blocked because I updated the firmware while my VPN was active with a US IP address.
    I have since returned the device to my reseller (an official Formuler distributor). They have up to 30 days to send me a replacement. I assume they will send the same device back after removing the geoblock.
    Before I receive the replacement, I have a few questions:
    • Will I be able to use the Formuler Z12 Ultra with a VPN that provides a US IP address? I plan to use some US services that require a US IP to work.
    • Does the geoblocking only apply during the initial setup? From reading the forum, I understood that this issue mainly happens during the first configuration, and that after setup the device can be used normally even if a VPN with a US IP is active.
    • I use an Aircove router. If in the future I accidentally update the firmware while my VPN is set to a US IP, could this block the device again?
    This geoblocking policy leaves me a bit unsure. If it turns out to be too restrictive, I may have to consider another device, even though I really liked the Formuler Z12 Ultra during the short time I was able to use it.
    Thank you in advance for your help.
