I had a similar issue in that a TV channel would play fine but without audio and only a restart would cure it, UNTIL I found that Legacy Passthrough option a couple of weeks ago, once selected I've had no issues since.
Posts by mikeyb
Good Morning,
Can i test it ?
Best Regards
No, it's been taken offline, you'll need to wait for a new update.
Do you have some link where this is described/explained? I have amazon prime for years on LG TV but with adds i get there correct HD/UHD symbol and 4K.
Do you need ad free Prime for 4K?
The ad-free tier has also been rebranded as Prime Video Ultra. Amazon tips "enhanced features" for Ultra subscribers, but what caught our eye was that the Ultra subscription includes "exclusive access to 4K/UHD streaming." That's concerning, since ad-supported Prime Video currently supports up to 4K (Ultra HD) on TVs.
You only get 4k on Prime if you pay for the ad free version now.
Not sure that's what the op is asking about mind you.
I’m having an issue after installing the new beta update where sometimes after putting the z12 ultra into standby and turning off the tv when i turn the tv and box back on the sound stops working and the only thing that gets it working again is if you restart the z12 ultra.
Please could this be looked into?
That happens to our box and we haven't upgraded to MTVOL 4 beta, we're still on 3. So it might me a box issue rather than the beta update.
Make sure your VPN (if you use one) is switched off before switching on the box for the first time or you could Geolock to the wrong purchase region which essentially bricks it and it needs to go back to Formuler to unlock it.
This info really needs to be on a label on the box or written into the quick setup guide that it comes with.
Is it possible to add BBC Iplayer app to a Formuler Z12 ultra ?
Downloader code 21203 is where I found it and works perfectly.
