Posts by John Glove
    Hi Sam,
    Good news: it finally started working again.
    For reference, the successful procedure was very technical. I pressed OK + Menu, then OK, then Menu, then OK + Menu again, waited a bit, switched the HDMI input, came back, pressed a few buttons again (simultaneously and sequentially for safety), and after about 24 hours the box apparently decided it was ready to cooperate.
    So either one of those steps worked… or the box just needed some time to meditate.
    In any case, pairing works now.
    Thanks for the help.
    Model: Formuler Z Mini
    Retail Box or Provider Box: Retail box
    Firmware version: latest (device currently stuck on pairing screen)
    MYTVOnline version: latest
    Box connected with: HDMI (TV) / previously controlled via HDMI-CEC
    Did you factory reset your device? and when?: 04/03/26
    Yes, factory reset performed recently after pairing issue.
    What issue(s) are you having?
    I bought the Formuler Z Mini about 1.5 years ago and everything worked normally.
    About one month ago the remote suddenly stopped pairing and I started getting “Pairing failed”.
    All LEDs on the remote work and the buttons light up.
    I bought a new remote control but the same problem happens: pairing still fails.
    I was able to use my TV remote via HDMI-CEC temporarily.
    After performing a factory reset, the box now requires remote pairing during setup but the pairing fails again.
    The device is now stuck on the pairing screen and I cannot continue the setup.
    What was you expecting to happen?
    I expected the remote to pair normally so I could complete the setup process.
    What happened instead?
    The pairing process does not start or fails and the device remains stuck on the pairing screen.
    How can we reproduce the issue you are having?
    1. Start the device
    2. Pairing screen appears (via Bluetooth menu -> add devices)
    3. Press OK + Menu on the remote
    5. OUI/MAC show in "search" screen and click to pair
    4. pairing fail message
    What have you tried if anything to rectify the issue?
    - replaced batteries
    - bought a new remote control
    - tried pairing multiple times
    - factory reset the device
    thank-you for any help and support
