Sam can you tell me when the beta will be online?
Posts by Bruno Rodrigues
If he will have an update in April, can he have a beta version to use the box?
I am connected with Mac portal. I already made 2 complete reset of the box but it does not change anything. Currently I also have a Z + that worked and there the same problem impossible to connect
I am in the same state as you, it will be necessary to wait for the update of Mytvonline that will leave in March / April
I try another provider on the same Z7 + and it works. I contacted them they tell me that there is no problem at home and it works with their Z7 +.
Will there be an update mytvonline to correct this because before it worked very well?
Hello, I have a connection problem with the server on Z7 +, the connection bar goes up to 100% but can not access TV channels since yesterday. But the VOD it works.
Sam I still have the same problem impossible to connect with Z7 +, 100% connection but no connection to the server. No channel list but VOD function.
Thank you but I have already done all these manipulation but without success. I even change the DNS formulate but it's the same, the download bar arrives at 99% but impossible to connect.
Good evening, I have the same problem with Z7 + impossible to connect with the MYTVONLINE application. Will there also be an update for Z7 +?
I often have the message mytvonline does not respond and also when I change the channel mytvonline application starts again alone.
When I run channels, the application is hard to follow.
I already put the box in the factory state but it changed nothing.
Could you help me before changing the box.
