Try to go fast to your username icon and then settings.
Somewhere you find "meta api". Turn that off.
If it won't help at all clear cache and above cache clear data. Then fill in your portal and at the username icon you find settings. There you find the meta api option. Tuen that off then.
I have tried!
I literally get 2 seconds, it’s not possible. So I obviously can’t use the app at all 🤷🏼♂️
