Posts by bart85
    I installed the latest version of expressVpn and it didn't change anything, I tried other servers and nothing helped... I tried with another IPTV provider to be sure and it's the same thing. I have no problem with other vpns, it comes from expressVpn for sure, 3 new versions since June 28th, there is a problem with expressVpn...
    Hello, Yes, the issue occurred after the June 28 update of expressVpn. I reverted to an earlier version but it didn't fix the problem. I contacted expressVpn and they couldn't do anything either, yet the customer service is responsive and listening, I was frank with them and I told them the problem clearly, anyway expressVpn is pre-installed on formuler Z12, so there is a commercial agreement, and no one has any illusions about the use of their boxes... The problem is that the problem arises only with mytvonline 3 and 4, with other players like Tivimate, I am not a problem, so there is clearly a conflict between mytvonline and expressVpn... I tried with other vpns and no problem... And I can't change my vpn, I took a 26-month subscription for 80€, the price was interesting... The solution for the moment is that I don't use mytvonline anymore but Tivimate which works well.
    Hello, Since June 28th, expressvpn no longer works properly with mytvonline 3 and 4, each time the channel is changed there is a latency of 5 to 10 seconds, and when you play a video in VOD, the connection crashes at the exit. I tried with another IPTV player (tivimate) and it works well... There is a problem between expressvpn and mytvonline 3 and 4...
