ok i am wait
Posts by buggiulucco
hello sam ,how many time for the launch a new firmware ?? many thanks
ok then I wait for the new firmware then I'll let you know if it makes the same mistake, but I was wondering if I have to do a hard reset or just delete the channel list ...
is the new firmware only for mytvonline? why if so it is only for iptv or am I wrong? thanks for the support
I bought it from kontrolsatellite in Portugal but the usb stick is the same as the formuler factory store...thanks -
hello friend i have buy the usb for dtt for s mini android but when i go to searcing the channels dvbt the device was in error and appair the writing
LOADING LAUNCHER WAIT A SECOND
I must the reboot the mini s android and remove the usb dvbt device , someone know how help me ...many tahnks
to edit the [lexicon]settings[/lexicon] use clark tech 325 import channel list from decoder enigma two linux and then export the channel list in .asvc format clark tech hd 265 put on usb and import the channel list in your android mini
