Hulu not working right. It doesn't play back smoothly. It works perfectly on TV and works perfectly on my Nvidia Shield.
Posts by big_dog1968
Amazon works perfectly on TV but that's a hassle switching back and forth. Also worked perfect in my Nvidia Shield.
The video appears washed out. I have an LG UHD TV with HDR. I am coming from Nvidia Shield send never had an issue. Also is GTV on latest version of Android TV? Singer it was since it's brand new but was curious
"Is not operational, because current HDR mode is not SDR"
Won't let me change any settings.
I am running my Z7+ on an LG 75UJ6470, it is a UHD tv with HDR.
Color, particularly on VOD and lower resolution images, shows renders skin tones way off, like it is over saturated. Turning off HDR helped, but then the images that looked great before, now look very flat. This doesn't happen when I plug my laptop in and run TV from it. Also adjusting color is very difficult because I have to exit mytvo to go through a menu to adjust it. Is there a way to adjust the picture as you watch it. Seems like there should but i cant figure out how so far.
When I am watching Catch up or cable news where there is a picture in a picture, like you often see in a news cast the image appears low res and blocky. This doesn't happen plugging laptop into TV watching the same service.
@SAM, where is a good place to learn about stalker. Didn't realize it played so big a role in what can and can't happen.
Are "extremcodes and 3mu " an alternate way for me to set up Formuler?
And thanks for your reply!
First thanks for replying. As to my match center question. I ask because I say the data populated on the APK but not in mytv. I don't know how it works and it isn't obvious that it would be something to take up with iptv provider.
Would love to hear from Formuler rep if custom groups and hiding groups is possible or if it will be in future updates.
- Is there a way to delete or hide unwanted groups? Seems basic, but I can't see how.
- Can I make custom groups, aside from 'Favorites'?
- Why doesn't match center have anything? Vader APK has it.
- PPV's can be found in live events, but EPG doesn't work right.
Thanks in advance.
Update. I just happened tonight. When I unplugged/replugged cord, it cycled repeatedly and installed updates like when new out of box. When home came up it made me go through set up and all my apps were gone. Not happy, as you'd imagine.
Same issue here. Doesn't happen every time. When it does, light doesn't flash, or turn green, or orange. Stays solid red. I have microSD, air mouse, via usb.
PS: You need to release air mouse/keyboard remote optimized for box. Included remote decent but still inadequate. Should be able to turn on and fully control formuler, (turn on) tv and (turn on and adjust volume) sound system from one remote, similar to what Directv remote does. I'd pay a reasonable amount for an upgraded remote with more programmable buttons, but with Formuler specific buttons. Why not allow F-keys to be programmed as well? Currently they do very little if anything. That would help some.
I'd like to try and test it. The EPG and time shifting have been killing me. I was on the edge of returning the box over these issues as they have been making it hard to enjoy box.
Just to be clear, the sound plays normally, but the video pauses, the video then resumes in sync with audio, which never stopped.
When I pause or rewind live video, then playback, video temporarily freezes, while audio continues. Video then resumes, jumping to catch up with audio which never stopped. It then plays normally for a few seconds then repeats, again and again, until I go to live TV. It's kind of like a repeating hiccup.
Well match center works on Vader website and in KODI. The main reason I care is that mytv gives me timeshifting, which is why I bought the box. If it works everywhere but mytv, I think it might be the software. Hope a mod sees this and comments a suggestion.
Match Center Group shows no channels. I have Vader and when I access on laptop, it works, but Z7+, no. Please help. Upcoming event that I want to watch on MYTV and can't see it anywhere.
FF and Rewind are key selling points to this box and shouldn't be this bad. Has it ever worked as advertised? Is there a seeing that can be changed to make it work right? They need to address this.
Also I was using catch up and it would buffer occasionally, but the weird thing was that if I pause and immediately pay it goes back to playing fine, but if I do nothing it will wait 10-20 seconds before resuming. Makes no sense.
Even in 1080 time shirt not working properly for me. Try to advance a few seconds and it just reverts to current sorry. You have to hold for at least five or six seconds to get advancement and then it jumps way out. Tried changing duration of jump in [lexicon]settings[/lexicon] but didn't seem to matter. Any suggestions?
Yes 1080p works but that is no long term solution. I have a 4k tv and paid double the price of the 1080p box. It should work at my TV's native resolution. If not, why advertise it as such and charge double? PLEASE don't consider this issue resolved.
