When i change channel it takes long a lot of time to load... I tested my internet speed and it´s around 94 mb/s and it´s not problem from my iptv provider.. I think it´s a problem from MytvOnline App, who can help me?
Regards
Regards
I have the same problem as you. With others app i have no buffer
I tested with VLC and perfect player and i had no buffers, and used the same things you said.
Hi
I have a lot of breaks with or without VPN connected using MYTVONLINE. I contacted my IPTV provider and the problem is not from them, because other users tdon´t have problems. I contacted my VPN service and the problem is not from them. I put the configurations like you said in the forum and the buffer continues.
Regards
Hello again
I tested with the wireless and now everything is allright! Thank you very much! ![]()
Best Regards
I´m using ethernet. I'll try it when I go home and tell here if it works. Thank you
After do a new factory reset, the error continues..
I try again two times, do the installation but the error still appear.
Hello
My firmware current version is 1.5.2
I´m in Portugal
Thank you!
So, I should wait for someone upload here? And where can i see that update firmware files here?
I did a factory reset and made the download again, and it continues to show up the problem..
Hello
When i download the new firmware to my formuler S Mini, when i restart the box, appears an android icon with an exclamation point and the firmware is not installed. What i can do to solve this?
Attached i send a photo of the icon error.
Regards
Did your speed decreased too much with the VPN?
Thanks for the answer
I try put a static ip in box and change the address in DHC pool, one number up to box IP. I turn on the Torguard app in TCP protocol and put cipher BF-SHA 1 and now is more stable. The speed goes to 40/50 mb
Best Regards
I would like to know if somebody here have solution for this problem ![]()
Hello people
I have two android boxes, one YokaTV Kb2 and a Formuler S Mini. In the YokaTv Kb2 when i connect the VPN with the torguard program and test the speed, the results are around 80/90 mb/s. In Formuler S Mini when i connect the VPN with the torguard program and test the speed, the results are around 20/30 mb/s. I have other programs off, why this happens?
I don´t connect the boxes at the same time and i use ethernet
Regards
