Posts by Dancia11
PKT HYPERION 5.7
Display Spoiler
- OE-Alliance 4.1
- GStreamer 1.13.0
- Python 2.7.13
- actual base
- new packages
- a lot of fixes and updates
- many new stbSpecial THX to TDT, Duckbox-Developers, OpenPLI, OE-alliance and all betatesters.
FTP login: root, passwd: pkteam
PKT Hyperion 5.7 IMAGE FORMULER 2017-Sep-02
ME 8.0
Display Spoiler
[align='center']
[quote]What is new in MediaSat-ME 8.0
- gstreamer 1.11.2 git
- python 2.7.12
- enigma2 20170411 base openPli
- Hardware ini1000de (20160121)
- kernel version- 3.12.1
- [linux-vuplus] enable usb serial device drivers for ARM receiversMain Features:
o MX GRAPHITE mod mamba65
o New GOLIATH HD Skin by mamba65 (vu+ hd51 end dm900)
o New Flash online plugins (all MediaSat-ME supported recivers)
o New MeFull Backup
o New Me appsMediaSat-ME:
o Blue panel
o Green Panel
o Extra [lexicon]Settings[/lexicon]
o Addons panel
o Compatible with OE-A and PLi plugins and SkinsINFO:
This Image has the latest drivers but CAN be installed in OpenMultiboot. The image does not need to be installed in flash.
This latest version of the MediaSat-ME series has been updated and improved for maximum stability and performance.Epg system:
- Integrated OpenEpg
- Rytec dedicated epg.datMain functions of the buttons on the remote :
OK button = Skin with simple information
OK button x 2 = Extra Info Skin
Blue button = ME Blue Panel
Blue button and then Red button = MEEpgPanel
Blue button and then Yellow button = System Monitor Panel
Blue button long press = Extensions
Yellow button = Audio menu
Green button = ME Green Panel
Green button long press = Subservices
Green button and then Red button = Fast Plugin Setup
Green button x 2 = Fast PluginAddons:
Green button and then Yellow button takes you to:-
Dedicated server for MediaSat-ME addons
Download and install additional packages from the MediaSat-ME serverInfobar / OSD :
Channel orbital location
Advanced Tuner Info: Sr Freq Pol Fec
Signal SNR, BER
Infobar picons
Characteristics of MediaSat-ME Panels
Blue Panel
OSD [lexicon]Settings[/lexicon] (OSD configuration)
Devices Manager
Usb Format Wizard
Inadyn [lexicon]Settings[/lexicon] (Configure Inadyn)
Swap File [lexicon]Settings[/lexicon] (Configure File Swap)
Hard Disk [lexicon]Settings[/lexicon] (Configure Hard Drive)
Tuner Server
Network Browse & MountpointsInfo Panel:
1 - Gui Setting (Gui configurations)
2 - Service Information (information system)
3 - About (info)Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Global [lexicon]settings[/lexicon] (global [lexicon]settings[/lexicon] EPG)
Setting Provider (ISP [lexicon]settings[/lexicon])Green Panel:
Fast Plugin Setup (Configure quick access to your favourite plugin)
Fast Plugin (Access your favourite plugin)
Addons (added)
Addons Download Manager (Manager for package downloading)Manual Install MEpackges (Manual installation of ME_tarbz packages)
Manual Install IPK packages (Manual installation of IPK packages)
Addons Uninstall Panel (Uninstalled packages)Credits :
Thanks to mamba65 for new skins.
Thanks to the group of Beta Testers.No you don't have to upgrade to the new MediaSat-ME image, this image is completely separate from the original MediaSat-ME image, this is simply an alternative image so we can offer our users more choice, if you are happy with your current image, then you can continue to use that image, if you want to try the new MediaSat-ME image then you can do so.
SFTEAM 5
Display Spoiler
sfteam-5-formuler3_20160921_usb.zip
sfteam-5-formuler3_20160921_usb.zip 74.4 MB
by CV-Skipper
Display Spoiler
QuoteDisplay More
Hi everyone,
Since I'm going away for a while I thought it would be nice to release a last batch of testing images containing upstream work from various OpenPLi forum-members.
So I'd like to dedicate these images to mx3L, christophecvr, samsamsam and Taapat for making it possible!
Lot's of changes this time, so be sure to read the full post before asking any questions
Let's first start with the things I didn't look into because I had to put my priority list together with the limited time I have..
- I did -NOT- look into the dFlash problem, sorry dreamboxco
- I did -NOT- add transmission, sorry doroshe
- I did -NOT- look into the fulan sh4 problems where certain FTA channels do not playback properly after recording, sorry Tony il Capo
- I did -NOT- add any Vu+ specific plugins such as Kodi, sorry mamamia
- I did -NOT- fix the lcd font for the DM800Se V2, sorry gassi 1950
- I did -NOT- look into the spark remote control issue, sorry paulbs
- I did -NOT- add support for the VisionNet Marvel1, sorry habab
- I did -NOT- enable the kernel modules for DreamTor yet
That doesn't mean I don't look into it later, I just didn't have the time for it.
Now here are the changes compared to the last release:
- Add support for the following receivers:
Herobox EX4 HD
Miraclebox Mini
Miraclebox Mini Premium Plus
Miraclebox Ultra
Xpeed LX3
Formuler 4
Xsarius PureHD
Mut@nt HD1500
- Latest gstreamer 1.9.0.1 snapshot based on recipes from christophecvr:
* Proper fix for HLS segfault on stop
* Re-enable the rtmp seeking and potential segfault fix
* gstreamer1.0-libav is now built against system ffmpeg instead (this differs from chri's recipes) *
* dvbmediasink patches for Vu Solo 4K, hd1265 and hd1500 from oe-alliance
- FFMpeg updated to 3.0.2 and is now installed by default *
- Backports to enigma2 for sh4 (mainly servicemp3.cpp related)
- Fix EPG on sh4 receivers
- exteplayer3 is now installed by default, thank you mx3L and samsamsam *
- gstplayer is now installed by default, thank you mx3L and samsamsam
- Mediatomb is now in the feeds
- MediaPlayer2 is now installed by default, thank you mx3L
- SubsSupport (for MediaPlayer2) is now installed by default, thank you mx3L
- No more russian tuxtxt
- It's now possible to set the debug level again in the UI-[lexicon]settings[/lexicon] menu, thank you christophecvr
- Latest enigma2 changes, thank you OpenPLi
- latest openpli-oe-core changes, thank you OpenPLi
- ServiceApp, thank you mx3L !!!
Known issues:
- On spark7162 (and 7111 probably as well) fragmented streams such as hls (m3u8) will skip and freeze a lot.
This happened sometime after the official Gstreamer 1.8.0 release and I didn't found the cause yet.
It is not related to the dvbmediasink since it doesn't happen on mips receivers and the code in the dvbmediasink didn't change.
Configure your streams to play with exteplayer3 instead, read below.
- * On the 64MB Dreambox models (DM800HD, DM800Se and DM500HD) there is not enough space to ship ffmpeg.
This means that exteplayer3 and gstreamer1.0-libav aren't installed as well because they depend on ffmpeg.
See my attached guide to copy over the root filesystem to a storage device.
- Some Dreambox remotes may behave very sensitive.
This causes button presses to register multiple times instead of just once.
As a workaround you can adjust the key interval:
Go to: Menu - System - Input devices - dreambox remote control (native).
Set "Change repeat and delay [lexicon]settings[/lexicon]" to yes
Set "Interval between keys when repeating:" to 200ms or 300ms.
Press green button (OK)
Now set the same delay for: "dreambox advanced remote control (native)" as well.
- DM800 first boot will take a while, please be patient. The next boot will be faster.
Thanks for the hard work from mx3L and samsamsam you can now play your IPTV streams with exteplayer3 or gstplayer instead of the default dvbmediasink.
Especially using exteplayer3 will give much better performance on playing HLS streams compared to gstreamer + dvbmediasink.
For example, playing DJING underground 720p never worked very well on my DM800HD and now it does
You can read all about it here: http://forums.openpli.org/topic/41198-se…nd-exteplayer3/
In a nutshell here's how it works.
In your /etc/enigma2/ directory you have your channel bouquets with the .tv and .radio extensions.
Inside these files there's this for example:Code#SERVICE 4097:0:0:0:0:0:0:0:0:0:http%3a//cdn.djing.com/tv/u-05.m3u8:DJING Underground (CDN)#DESCRIPTION DJING Underground (CDN)
By default this will play with the gstreamer dvbmediasink (which is currently broken for sh4).
If you like to play your stream with exteplayer3 instead you should change the 4097 to 5002, like this:Code#SERVICE 5002:0:0:0:0:0:0:0:0:0:http%3a//cdn.djing.com/tv/u-05.m3u8:DJING Underground (CDN)#DESCRIPTION DJING Underground (CDN)
You can also change it to play with gstplayer using 5001:Code#SERVICE 5001:0:0:0:0:0:0:0:0:0:http%3a//cdn.djing.com/tv/u-05.m3u8:DJING Underground (CDN)#DESCRIPTION DJING Underground (CDN)
Now let's say you'd like to convert your entire bouquet to play with exteplayer3, simply login to your receiver with telnet/ssh (use PuTTY for Windows).
And issue to the following commands:
First stop enigma2:
Then change your bouquet to make all streams play with exteplayer3, lets say userbouquet.favourites.tv:
Then restart enigma2:
That's it !
You can also make exteplayer3 the default backend for playing back everything.
Go to Menu -> Plugins -> ServiceApp and set exteplayer3 as default.
Keep in mind that with exteplayer3 or gstplayer as default backend you will not have support for external subtitles (.srt for example).
That's why I've added MediaPlayer2 and SubsSupport from mx3L.
I haven't tested it for myself yet, since I simply changed my IPTV streams with type 5002 (exteplayer3) so everything else like DreamPlex for example keeps using the dvbmediasink.
Play around and let us know your findings!
thx MastaG-Unofficial- Gstreamer 1.9.0.1 images 2016-05 -based on- OpenPLi 4
NFR4X MultiBoot OK
OpenSPA
Display Spoiler
[url=https://openspa.webhop.info/#Descarga%20de…enes%2FFormuler]OpenSPA
Formuler
PKT IMAGE HYPERION 5.2
Display Spoiler
Display Spoiler
Hi there,
Since my last round of images had HLS broken, I've created a quick round of new images using christophecvr's new gstreamer recipes.
Also it should be possible to do an online upgrade (if you have sufficient free space).
Changes compared to previous release:
- New gstreamer 1.9.0.1 recipes based on christophecvr's github (small changes for PLi4)
- Upgrade glib2.0 and some other components like gobject-introspection to satisfy the new gstreamer recipes
- gstreamer1.0-libav is built using it's minimal libav with only support for wma (thank you chris)
It's pre-installed on all receivers except for the ones with only 64MB of flash (dm800/800se/500hd)
- Full ffmpeg 3.0.1 package is in the feeds for use with IPTV Player's exteplayer3 (thx to Taapat for the original bbappend)
Login with telnet and issue: opkg update && opkg install ffmpeg
- Latest openpli-oe-core changes
- spark: libeplayer3 is pre-installed now (also in the feeds) for movie players with support for this library
Note: servicemp3 still uses gstreamer
- spark: some OpenPLi enigma2 backports (since Taapat doesn't maintain his enigma2 branch anymore)
The servicemp3 memleak patch has been applied with some other patches/commits I found useful
- spark: don't force async mode on the dvbaudiosink anymore, it's now the same as all other receivers again
So in short, this release should have HLS and mp4 playback working again. (thank you mx3L and chris).
Also thanks to samsamsam IPTV Player should be working again.
It's now compatible with OpenSSL and if you install ffmpeg from the feeds, it will install exteplayer3 for you (also on sh4).
Please refrain from any (cam/smartcard)-emulation or clone-receiver discussion.
Thanks for testing and be sure to report back your findings.
thx MastaG
-Unofficial- Gstreamer 1.9.0.1 images 2016-04 V2 -based on- OpenPLi 4 -
cccaminfo
by CV-Skipper
Solche Sachen haben hier im Forum nichts zu suchen !
Ich habe Deinen Link deshalb entfernt und fordere Dich auf, Dich zukünftig an die Forenregeln zu halten.
Wäre schade, wenn wir zu anderen Maßnahmen greifen müssten. -
extraappstore
Display Spoiler
SFTEAM R4.1.3 Image
Display Spoiler
test OK
im aktuellen openLD 2.6 ist auch der GStreamer 1.71 enthalten
OpenNFR im flash und OpenPLi-4 / Gstreamer 1.7.1 (master git) images 2016-01-05 im pendrive
