Micro SDHC 256 GB test OK
- Szybkość 10 mb/s
Działa z tunerem formuler, koszt 69,99 zł
Display Spoiler
I test the cart ..ok to 8GB no 256GB Betrug !!!!
- Szybkość 10 mb/s
Display Spoiler
Edit from Admin: LInk deleted, no ULC Links please.
QuoteDisplay MoreOpenPLi-4 / Gstreamer 1.7.1 (master git) images 2016-01-05
Please reflash your receiver since a software update will most likely fail.
Especially on spark/spark7162.Changes since previous release:
- Gstreamer snapshot updated to 1.7.1:
* The mp4 issue when playing from remote locations has been fixed upstream, so I've dropped the revert.
* Libsoup has been updated so I've dropped the revert for the old libsoup as well.
- DM800Se V2 and DM500HD V2 kernel config has been cleaned and more in sync with PLi's config for the other Dreambox models.
- More free space by adding a task before do_package_write_ipk which will upx compress some binaries.
* This should give us a few more MBs to work with (Dreambox *cough*).
- Major rework of the meta-fulan BSP for spark thanks to Tapaat for helping me out.
* Now using Tapaat's drivers which fixes the frambuffer (and 22khz?) issue.
* Enable of the zram module.
* Shipping his wifi drivers.
* VFD time is now synced every 5 minutes using a cron job.
* Software update and plugin-installation has been fixed.
* Using Tapaat's lirc config for spark and spark7162.
- The usual batch of dvbmediasink fixes by Christophecvr and mx3L:
* A brand new divx/xvid bitstream unpacker by mx3L should fix playback of avi files with wrong fourcc.
- Libsoup has been updated to 2.52 (from master-next).
- Refactor wifi drivers a bit on Linux 2.6.18, not auto-loading the mt7600 anymore, the correct driver should hopefully be loaded when you plugin your wifi stick.
Changes compared to openpli-oe-core gst-1:- Ships with gstreamer upstream master git:
Using the same patches as openpli-oe-core gst-1 with only these changes:
Removed: 0001-baseparse-post-tag-list-when-avg-bitrate-changes-at-.patch
because this patch was already checked in upstream.
- Every receiver uses christophecvr's multibox dvbmediasink.
- Using libtrmp and rtmpdump from oe-alliance.
- Some small enigma2 patches for Dreambox receivers (ac3/dts bypass and blanking on zap support).
These are only applied for Dreambox receivers.
- AAC to AC3 transcoding V2 by mx3L (requires a fast cpu).
- IPTV Player from samsamsam included (thx to Athoik for the recipe).
- Large list of public IPTV streams included thanks to the Japhar Team.
- Updated libcdio and cdtextinfo for audio-cd support by christophecvr.
- DM800Se, DM7020HD and DM800SeV2 driver upgraded to 20151201:
added si2166b blindscan support.
- Using aio-grab source from oe-alliance which includes fixes for spark receivers.Known issues:
- DM800 first boot will take a while, please be patient. The next boot will be faster.
- On spark/spark7162 you need to set 'boxtype = dreambox' for oscam dvbapi.
Please use 'duckbox' instead.
- On Zgemma Star you cannot use full HD skins.
This is a hardware/driver limitation.
Please don't try it, it will crash enigma2.
- Some Dreambox remotes may behave very sensitive.
This causes button presses to register multiple times instead of just once.
As a workaround you can adjust the key interval:
Go to: Menu - System - Input devices - dreambox remote control (native).
Set "Change repeat and delay [lexicon]settings[/lexicon]" to yes
Set "Interval between keys when repeating:" to 200ms or 300ms.
Press green button (OK)
Now set the same delay for: "dreambox advanced remote control (native)" as well.
TODO:
- Linux 2.6.18: Create a plugin / ppanel to select which Realtek/Ralink driver to load on startup (eg. rt3070, rt55xx, mt7600), since they cannot be loaded at the same time.
- Linux 2.6.18: Look into the v4l usb drivers.
- Add Spark specific plugins by gorski.
- Add meta-ini from OE-Alliance and shape it up for openpli-oe-core.
Download:
https://mega.nz/#F!z08HlZyA!Upawo32ILooVVyTRve-soQ
Happy testing everyone!
https://mega.nz/#F!z08HlZyA!Upawo32ILooVVyTRve-soQ!y0tFyK5ROpenPli-4-MastaG-20160105
Image 4.0 MastaG
QuoteDisplay More
OpenPLi-4 / Gstreamer 1.7.0 (master git) images 2015-12-10/11Users running the previous Gstreamer 1.7.0 image, should be able to peform a Software Update!
A quick rebuild because we got a report that bug: https://bugzilla.gnome.org/show_bug.cgi?id=758928
was fixed by this commit: http://cgit.freedesktop.org/gstreamer/gstr…29936f8b963e24bPlease test these two streams if possible and report back:
#SERVICE 4097:0:0:0:0:0:0:0:0:0:http%3A//xg5tbqm52h1pot9.babahhcdn.com/witch/season1/304680.mp4:Dougnut test
#DESCRIPTION Dougnut test
#SERVICE 4097:0:0:0:0:0:0:0:0:0:http%3a//cdn.phoenix.intergi.com/19850/videos/4357110/video-sd.mp4:Test MP4
#DESCRIPTION Test MP4Hopefully the bug that prevents playing mp4 files from remote locations is now fixed
Using the same patches as openpli-oe-core gst-1, no changes or extra patches added.
Only patch I've removed is: 0001-baseparse-post-tag-list-when-avg-bitrate-changes-at-.patch,
because that patch is already accepted and commited to upstream git.
- Updated libcdio and cdtextinfo for audio-cd support by Christophecvr.
- Spark images includes the pti.ko from OpenATV so softcam's should work now.
- DM800 kernel will now always pass the vermagic check when loading modules.
Now you can try and load any DM800 2.6.18 kernel module from OE1.5 to 2.0.Known issues:
We're using the OE-A drivers and 'duckbox' doesn't seem to work on these.
- On spark/spark7162 you need to set a skin which doesn't resize the framebuffer.
Because sometimes it doesn't scale back to fullscreen.
I've included the MX-HQ7 skin for use as workaround.
- On Zgemma Star you cannot use fullHD skins.
Micro SDHC 256 GB no OK
OK NFR4X MultiBoot
opennfr-5.1 formuler1
on USB pendrive
SanDisk Ultra Micro-SDHC 32 GB
https://yadi.sk/d/I4i6yYG4mKfWFrudream-5
https://yadi.sk/d/OaAMikxGf6yhG
Maximum file size: 10 MB on filebase does not allow to upload image
