Thanks, all 3 seem easy to setup then! ![]()
Posts by eva
Thank you very much, very helpful answers!
Are the S and Z7+ Android boxes easier than the F1 to setup for IPTV? I am familiar with both Android and Linux, but far from an expert.
Eva
Hi again,
Could I get some help on this one please?
I'm in a situation where I need two iptv boxes for two different locations. At one location I only need iptv, but at the other location I could use satellite if I wish. In the latter case a combo sat/iptv box like the F1 would be very practical.
So how does the iptv part of the F1 compare to a "pure" iptv box like the Z7+ or a combo box like the S Turbo?
Are Z7+ and S Turbo faster in the menus, have better picture quality or have more features than the F1?
Or does the F1 - being a premium box - have any features for iptv that Z7+ and S Turbo lacks?
Kind Regards,
Eva -
OK, thanks.
I do have DVB-T signal coverage and it works good with my present tuner box, albeit with some occasional dropouts.
I'm just wondering, since the OP had a problem, could it be that usb tuners in general are a little bit weaker for reception than inbuilt tuners?
How does the F1 do IPTV compared to Z7+ and S Turbo?
How do the 3 boxes compare in terms of speed and features for IPTV?
Kind Regards,
Eva -
Hi again,
Does the USB DVB-T tuner work with Z7+ or not?
I think there is a need to have programmable buttons for the volume also.
If you have the volume on your TV set to very low the last time you used it, it may be too low for use together with the Z7+, and then you'll have to dig out the TV remote to raise the volume to an acceptable level. After that, you could go on with the Z7+ remote to adjust volume - but you can't rely on the Z7+ remote alone if the volume on the TV is too low to begin with.
Programmable volume buttons would solve this, don't you think? What are your opinions?
I want to buy a Z7+ and the USB DVB-T tuner so I need to know if there are any issues with this combo.
It seems the OP had a weak signal only when using the USB DVB-T tuner but not with his other box.
Did this issue get resolved?
Kind Regards,
Eva
