Posts by Elbyrneo
    Why not just load vlc onto PC and input M3U data into vlc ?
    Sounds good. Can I locate m3u data myself or would I need to ask my IPTV provider? A little reluctant as they prefer only one device to be used that's all. Is there an easy way of getting myself?
    Hmmm don't think this is possible? Not with MYTVONLINE I'm guessing.
    You want to essential watch your MYTVONLINE stream on a PC?
    Well I don't necessarily need the user interface of MYTVO but would like to either screen mirror to a PC (I have a logitech harmony so can control the box from any room) or just play the IPTV feed that I'm getting in VLC on the PC etc.
    I was able to with an enigma2 box before, not that I can remember how!
    Hi there
    Hoping you can help.
    When watching on demand media, there is a strage sound vibration or distortion every 5 mins or so. It just lasts 2 or 3 seconds but really annoying as any sound or dialogue cannot be heard.
    Happens whether I use soundbar or just tv speakers.
    Doesn't happen when I play same media on another box (e.g enigma2 box). Doesnt happen when watching live IPTV content.
    Is this a known issue ?
    Thanks!
    Hi there.
    June update working great and EPG much faster, thanks!
    I have one issue - does not happen with same provider using an enigma box.
    Basically I have EPG for all groups e.g UK Entertainment, UK sports, UK movies etc.
    But for two groups of channels (US movies and US sports) the EPG data does not come through for any of the US channels in these groups. Channels work perfect just no EPG data.
    What's best course of action? Get a M3U file? Xtream Editor. Not familiar with the formuler z7 box so easiest solution best!!
    Thanks!
    An idea for development (unless existing functionality that i wasnt aware of it).
    When you are in the standard EPG and want to go to a different group, is there any easy way to navigate? E.g. I'm watching movies but want to see what is on in the sports group.
    I find I have to exit the epg, then either press group on the remote and select a group, or, exit the epg and press ok to bring up the channel list and then go left and select a group, select a channel in that group, and then bring up the EPG.
    Am I missing something?
    With beta testing showing a much more responsive epg, would like to stay in the EPG but view different groups by instance selecting fast fwd / rwd buttons to navigate through groups..
    Thanks!
    Hi there
    Are there any plans to introduce some user configurable [lexicon]settings[/lexicon] for the EPG. For instance show more rows of channels, reduce fonts and show a wider time range.
    The current view is quite limited in showing a small number of channels and a limited window of time because of large fonts and the preview channel taking up lot of space on the top half.
    Would be a great feature. A lot of rival images for instance off this including removing picons, more rows of channels, zoomed out view for wider time range.
    Saves on scrolling!
