already found it.
seems that the box does not Export data that this is a h265 channel.
I marked it in the Programm then uploaded again and Service error was gone for all UHD.
Also for Sound here you have to mark AC3/DTS for each UHD channel again in the C-Editor Programm.
Otherwise no Sound for most UHD Channels.
By the way i use a Durtch Canal Digitaal Smartcard but the Card Reader says something like invalid Card.
I guess i Need sperarte plugin for the Card Reader. Were can i find/download it?
Is there also a plugin with wich i can share my Smartcard to another Receiver in my house over my Network?
Posts by maus
i hooked up the box to my UHD tv and now i can select 2160 HZ.
Ony issue that i have for now is that all UHD and some other HD give SERVICE ERROR message (No picture only sound)
But this issue i put already in another thread and happens after channel upload by USB stick after list was reworked with C-[lexicon]Editor[/lexicon] program. -
Hi
I downloaded the Channel list from the receiver with 23,5 19,2 and 28,2 sat channels to an USB Stick.
Next i imported the list to C-Tech [lexicon]editor[/lexicon] 3.25 and shifted channels to my perferred places.
After this i exported the list to the .asvc format file like in the instruction on this Forum.
Uploaded the file to the receiver again and everything works fine.
Execpt after this i experience that all UHD and also some HD channels give the message SERVICE ERROR with yellow triangle sign when i select them.
Is there anybody who had the same issue and maybe has a solution.
Thanks in advance. -
Hi Sam
all my Problems are solved with thanks to the guy from the store were i bought it:
1) my box was not bricked at all, the message on the Screen OUT of RANGE means the Monitor could not handle the Resolution of the box. in my case it was hooked up on an old TFT Monitor whicjh caused this.
Whem i put the box to my FHD Monitor i saw that i was landed in the restore menu and that i had to choose the Language. Thats why i all the time thought that it was bricked with the LANG message in the Display.2) I also managed with the help of this guy to load the new channellistfile in the download menu Option.
At first i saw no files after putting the usbstick in the box. The Guy told me JUST PUSH THE LEFT BUTTON on the remote and there the file was.All and all i could have saved myself hours of work by calling the Guy from selling store but anyway it works now.
Last question to you is if this box is really 4K? with that i mean can it really produce a 4k Picture for my 4k TV when it is in Satellitebox mode since i see in the settinngs only 1080P as max Resolution.
Or does the the box have to be hooked up to a 4K TV before it showas the 4K Setting. Up till now i was only on a FHD TV. -
by the way what does this message Lang or lan6 in the display mean. Is this the launcher?
Hmm now I read that from version 1.6 the software reset tool by means of the .ird file should not be used but now by means of pressing the red button , waiting for the green red led to blink and then push 1 button? Maybe because I used the ird file first the Methode with the red button does not work anymore?
when I use the red button I see the logo turning but end up again with out of range on display and the Lang message in display. -
Hi Sam tried at least 5 times now to use the reset factory tool. Also everytime made sure that only the .ird file was on the stick. But I always end up with that Lang message in the display. I also tried Dons method.because version 1.6 is on the box and then in the end I see the turning logo on the display and again end with the Lang message in the display.
Hi Sam,
i checked the file names and they were ok.
even created new ones with right names but files are still not found .
after this I put the receiver back to factory [lexicon]settings[/lexicon] and after this my receiver was bricked.
next I use the reset tool with the the.ird file but during booting I only get a message OUT OF RANGE on the screen. The display goes from boot to load , st1 end end with a message something like „Lang“. It stays in this position. Sometimes also the box switches of and shows the time 00:00 in the display but stays bricked.
anymoore suggestions. By the way I used the up channel button during boot and load but no progress bar appears. -
Hi
i downloaded my channel list to a usb stick from the receiver.
i also exported another channel list with the c-[lexicon]editor[/lexicon] program to the same usb stick as an as coach format file.
when I put the stick in the receiver and try to upload the new channel list file I get the message that there are no files on the stick?
when I put the stick in my pc I see that the receiver has written the old channel nsvc to the stick.
also tried with other usb stock same problem.
am I missing here something???
i selected in the android [lexicon]settings[/lexicon] the usb stick as standard external memory.
who can help me?
