Posts by z7+Lover
    My Z7+ (MyTvOnLine) won't connect to certain playlist URL's/M3U's. I've tried with 2 different providers.
    Please note I have already completed the factory reset, the software reset and a reset using the USB stick/formuler reset tool. The Z8 box I have works without issue for both providers using mytvonline2.
    The results of the Z7+ testing are below:
    Using the beta:
    Software update: 2.0.7
    Firmware Version: v1.2.85
    IPTV version: 1.9.85
    I get the following errors:
    Provider 1
    Playlist Error: Data load failed.
    When you try to exit the connection mytivonline hangs at cancelling connection and you have to unplug it to get back to the main android screen.
    Connecting to the same urls works fine from other apps. NOT mytvonline.
    Provider 2
    Channel List Empty.
    Any ideas on an ETA for a fix?
    Hello, I've noticed recently that when I configure the portal the first time it runs fine, after I exit mytvonline and load it again I get the error that flashes on screen for a second CHANNEL_LIST_EMPTY?
    Any Ideas on how to fix this issue?
    Z7+ software version 1.2.16 Software Revision r13015.
