XC Api Portal is supported via panel_api.php or player_api.php?
Posts by Gabriel
Well anyone from the team can give some support?
Yes, is the way how to use XC Api Portal on Formuler.
How to use MAC/ID portal, Xtreme Codes Api (XC) and M3U Url on Formuler Boxes.
Hey Uncle Sam,
I hope you are well
i know that but doesnt work , i was hoping to see a working json format result for formuler , so i can apply that into my server side (PHP) format so it cant load into my formuler.
I just need dummy data but true variables names.
Regards
Hi everyone,
is there a way to change the way tv series been displayed on mytvonline1.
Once we Click on Tv Series display all Parent shows (such ZplusShow, ZShow , ZAndroidShow)
Now once u click on ZplusShow by Example it show all season of ZplusShow like ZplusShow S01 , ZplusShow S02...
refresh that same grid View
once u click on ZplusShow S01 it will show all episodes of ZplusShow S01
all been displayed in that Grid.
Regards
Can you give me basic json result mixed of tv , vod & tv series (with subseries) (just dummy data) working with your formuler so i can tweak my side has i cant get it to working on my fomuler using mytvonline v1.
should i just add portal , username & password and check use login?
Regards
I was wondering if XC Player_API supported? action=get_series... & action=get_series&category_id=X...
has i have pbm loading Series via Portal , so i was wondering if via XC API could load all including tv series
Regards
Btw i'm not asking for MyTV Online app update or anything
Just to see the reason why the app fail loading the channels , missing parameter or variable type...
box is connected via LAN
I only tried Wifi after i got channel_list_empty to analyse traffic (get box response to analys)
I already contacted over PM
i really appreciate your help , cause i made all normal stalker request manually and all working fine...
is there a way to contact me over pm so we can fix it easly , i'm sure we will find a fix as i'm a dev also
Cheerz
pick content
between 03-28 01:39:23.133 13700 and last content file as it was the time usb was inside and loaded portal -
Not using Ok2 and nothing to do with channel playing or not , it's even not listed
This is Dev/Tech discussion thread
@SAM did you saw the log ?
Thank you
Here you mate,
I just renamed dns to sam.me
Let me know as i have invoked the stalker get_all_channels manually i get results OK and Magbox is OK
so i presume should be some issue on parsing or typo error
I appreciate it
Hi ,
I got the log file now
how i can send it to you so we can analys/debug?
i'm trying to locate the error
Thx
It happens when, after start? When this happen you close MOL and start again, same message? Do you use under System -> start App - MOL ?
Under System -> Start app : none
It happend always closed & started many times , no luck
However vod is listed fine & workingIs there a way to debug or something so we can see what is the reason it return prompt message channels_list_empty ?
is it the response timeout set inside the app ?
i'm using Formuler z+ last firmware & updates...
I have here Magbox same portal all loading fine...
is there anything i can help you so you can detect the issue ?
Regards
Using MyTVOnline app and getting on LiveTV Channel_lists_empty
however Vod loading fine and working ??
I tested on Magbox same provider and works fine
Is there a way to debug and see what is the reason ??
Cheerz
