Posts by yamaha06
I feel the same
I’ve bought three s mini’s as I thought the sat would be good as a backup measure but finding its completely useless.Also for starting myonline tv on startup StewD can be accomplished by downloading auto start (free) from the PlayStore however this feature does not work from standby. However there is a sequence to stop these boxes from going into standby.
+! need this feature my provider has upgraded
This feature should be implemented on the s series as the satellite side should be used as backup only as it buggier than the mytv app. I bought three s series thinking that the myonline tv app would still have priority but obviously not as i have to initialise the app every time I turn the tv back on.
Shame it hasn't been developed for IOS.
Hi was wondering whether devs could look at getting an app to control formuler boxes similar to firestick. I have tested out CetusPlay however the only button that works is the home button and can launch apps from phone.
thanks
Tried without any apps in the background and also I am aware of the format issue so no usbs connected but still no success
Hi I’m unable to get away with the my online tv app tried all settings on the forum but still constant loading. So I’ve tried to stbemu which is working flawlessly apart from there’s a problem with the box as after 30 mins to an hour I get the launcher loading problem and have to reset the box. I’ve tried both firmware versions and multiple stbemu settings none worked. Is there any fix for this?
Hi pretty new to the formuler box I have three mini s boxes that work great apart from the epg. I have to scroll down each channel in the list for about 3 seconds then it will load the epg for that channel. Is there a fix for this issue? Is this the same issue as the z7+?
Would like to try the beta also just bought two boxes this week and having the epg issue.
