Any other remotes that work on the formuler?
Would like to use a small remote
Hi
Any idea why no EPG is showing? I've cleared epg data and rebooted but still nothing.
I used same provider line on smart iptv app and full epg is showing.
Cheers
Finally my z7+ is now superb with the epg beta.
Please keep it this way. The epg now seems to be fixed. 👍🏻
Any idea when fix for epg coming? Or even a beta?
I've resorted to using smart iptv app on formuler z7+
Same iptv provider and epg is perfect on smart iptv app.
On MYTVOL epg is really bad.
Is there a fix coming soon?
Beta worked better than new official update.
Running out of patience. I really would like to love this box but can't.
I have a buzztv xpl 3000 and epg is instant loading.
What exactly is the problem with epg on z7+?
How can every other box or app get it right and formuler can't?
If formuler want to be a leader in iptv boxes they need to get the basics right.
How much?
Where u based?
Yea it's very annoying. How can they not get the epg to be working properly is unbelievable.
Take for example a firestick. U can install smart iptv app from the amazon store and the epg works perfectly.
How can formuler not get it right?
Giving it one more week and if not fixed I'll be selling mine.
I really want to like the z7+ but one of the most important things on iptv not working properly.
Giving it one more week to see if epg is sorted.
It's so frustrating.
Mag boxes, xiaomi mi box 4K boxes, smart iptv app have all perfect epg.
Genuine question why can't formuler mytvonline app not get epg properly working?
If a €60 box running with smart iptv app can get it right why can't mytvonline app?
Same here.
EPG was alot better before official software release.
I now have to scroll through every channel to see what's on as before it was nearly instant.
Any ideas?
Is smart iptv available from playstore or market on the box or do u sideloaded it?
Go to settings, system, then press 0227 on your remote. If there is firmware to update then update.
Then press back button to home screen and go into market.
Go to mytvonline app and install the second one.
Reboot box and see if any better.
Worked for me.
Hi
I know there's issues with the epg.
I'm running the beta epg but the epg is showing what's going to be on in 1 hours time beside the channel name.
Is this a known issue?
I have the time and date set correctly and it's not a provider problem either as have it on a different box too and epg is correct.
I've tried changing the epg to UTC in settings but still the same.
