Posts by wawa7262
Yes I have installed the latest update and after EPG populates I am on a channel and then press (>) to use single channel EPG it says loading and never loads.
Pleaes help, the My TVonline single channel EPG does not load. Does anyone know how to fix this?
Thank you.
My Formuler z7+ remote control is interfering with my Vizio sound bar. When I press any of the following: stop, play, rewind, fast forward on the z7+ remote it changes the volume and sound bar settings. Is there anyway to reset the remote control or fix this so that this problem stops?
My set up is: SB3651-E6 VIZIO SmartCast™ Wireless Sound Bar connected to HDMI ARC on TV, and Z7+ to HDMI port 2 on TV. if this helps.
Thank you.
Thank you very much!!
I really appreciate your help!
What is the USB 3.0 max size limit amount or size limitation that can be used for recordings on the Formuler z7+? I am thinking of purchasing a 6 TB external USB 3.0 portable hard drive for recordings as my husband and I record a lot of live sports games and movies. It is compatible with android 6.0 and above. I have searched for this answer with no luck. Any information you can give me is greatly appreciated.
Thank you.
