Yes SD ext4 formatiert - Paragon Hard Disk Manager 15
Posts by Kirillm
Ok
Integral SDHC 8GB Class 4 SD-K08G JAPANTranscend SDHC 16GB Class 10 TS16GSDU1 Taiwan
Formuler F3, OpenPli4
While maunt through fstab
DCC_E2->Telnet command
blkid/dev/mmcblk0p1: LABEL ="KIRILL" UUID ="de36846e-093f-bbd4-3ff5-cb92443acd47" TYPE "ext4"
Prescribed in the etc/fstab
UUID=de36846e-093f-bbd4-3ff5-cb92443acd47 /media/hdd auto defaults 0 0Create a folder in the hdd media overloaded and so maunit in media/hdd/
Checked today modem 2G/3G Huawei E1550 working plugin enigma2-plugin-extensions-xmodem_1.0_mips32el. OpenPli
Today, TL-WN823N tested it on a chip rtl8192so idle speed (IpTv) on a new kernel 3.17.3.
Working file rtl8192cu.ko found only on openATV image.Replace the path lib/modules/3.17.3/kernel/drivers/net/wireless/rtlwifi/rtl8192cu/ for Open PLI or respectively to its image.
Took the TL-WN823N 300Mbps Mini Wireless N USB Adapter - holds 270Mbps speed, RT-N56U-->F3
http://www.tp-link.com/en/products/de…model=TL-WN823N
