out of curiosity, I assume your speed testing via speedtest.net app? Try also testing speed via FAST.com app (Netflix speed test app). I also use a USB Ethernet adapter and see weird results quite often. ie also I only get ~60ish from speedtest but will get my full 120 from fast.com.
Let me know what you find
Thank you for the response. I have tested with speedtest, fast.com and a random speed test app from the market and get the same results until I unplug/plug the Ethernet cable. Then back to full speeds again. It works fine until I power off the unit or put it in standby. Maybe I'll try another adapter to see if it does the same thing. Doesn't make sense why a quick unplug it the Ethernet cable would be needed though.
