hi sam. They sended me a new box because it was crashing a lot. After i customized my tv list on c tech. Epg disappeared again. Can you help me pls
Posts by krimo12
my s mini also crashes sometimes. i get a green screen or iet switches itself off or the box doesn't react on my remote controller.
any suggestions?
i onlis watch satelite tv
vlc is working with .ts files
hi Sam,
i still have the same problem even with the update you did on my box.
no info on EPG
thx mate,
problem solved, i could't find the number 1-2-3-4 diseqc.
all satellites where on NR. 1 ,now i changed the nr's for each lnb
hotbird 13.0 on 1
astra 19.2 on 2
astra 23.5 on 3
astra 28.2 on 4
(this depends on which lnb on which port on the switch you have connected)
hy
since i used the c-tech editor to customize my favorites, i can't get any epg info? (dvb-s2) tv
i uploaded my tv channels to usb, usb upload to pc (c-tech )and customize favorites, after that i exported the list to usb and uploaded to the reciever.
now i have no EPG info.
Of course should be also for each Sat. the right diseqc chosen. can you show me i picture of this how to do choose for each sat. the right disecq or an example in my situation 19.2 23.5 -28.5 - 13.0
i tried to scan astra 19.2 , all okey i got my channels
astra 23.5 --> gives me the channels of astra 19.2
hotbird --> scans everithing channels ar ok.
astra 28.2 --< gives me channels of astra 19.2
i have also the problem to configure my satelites. i hav 4 LNB, astra 19.2 astra 23.5 astra 28.2 and hotbird 13.0
i have 4 lnb's connected to a switch 4x1--> coax to reciever.
with my dreambox everything worx well, easy to select sat LNB - like astra 1 A. astra 2 B astra3 C hotbird D
on this box you can only select 1 sat like 19.2 at the time?
who can help me here...
