Posts by festo
    Hi! please, implement in the future software the ability to select a source for time - satellite or the Internet, as it is implemented on an analogue from Openbox, because there are some satellites where the time zone differs from the local one, the receiver automatically picks up this time, the EPG changes, the time gets lost, back it is not refundable. Now I set the time manually, but I ran into a problem that after restarting the receiver, the time is reset to 04/10/2017. so timing the network as the main source would help me. thank!
    Hello! Since the purchase of the receiver, it has problems with wi-fi, it can work for an hour, several hours, minutes, but in the end wi-fi is still turned off, so that I can not connect to the router or can not turn on the wi- fi, the receiver thinks-thinks, but wi-fi still does not turn on, you have to reboot the receiver many times, this problem was on both software 1.4.8 and 1.5.0, and still remains at 1.6.7, cleaned the receiver , changed the firmware - it does not help, the box is new, from the store. Tell me, does anyone have a problem with wi-fi and can this be fixed? or is it a bug and the receiver needs to be changed? Thanks.
