Posts by Lucky13
    All working now my friend, soundbar needed a full reset then when turned on, sound was coming through so all is well 🥳🥳🥳
    Great work my friend! Good job!
    So now with the formuler remote you can do volume up and down from tv, but the tv gives the signal to the soundbar? So the soundbar goes louder or less louder?
    Ok I checked soundbar and av section in the remote app and now it shows Panasonic. It changed volume on the second code it tried.
    So now that is set to my soundbar and volume keys on side work with volume up and down.
    But still no sound
    How many hdmi ports do you have on your soundbar?
    Is it in the right hdmi port? Some soundbars have 1 hdmi out (tv) and 0 or 4 hdmi in ports. (devices)
    You should use hdmi out (arc)
    Which soundbar you have name and type.
    It must work normally on both hdmi arc. Are you sure you have a hdmi (e)arc on your tv and your soundbar?
    Soundbar is connected with hdmi arc to hdmi arc in soundbar.
    Take remote off soundbar and set it to a normal volume level.
    In formuler remote you setup the tv brand.
    If that not work, try in formuler remote to set the remote at "setup volume control" and then choose "soundbar & av receiver". Check if your sounbar brand is there.
    But watch out: take first tv remote and set it to normal volume level.
    And then try it with formuler remote to upler or lower volume level of soundbar.
    Play with it. I must work my friend. Normally it works already with tv brand volume if hdmi cable puts in hdmi (e)arc and in soundbar.
    My Formuler Z12 reboots randomly while watching YouTube, M3TV, and sometimes Emby, even after a factory reset.
    Apologies, but this box has been a real disappointment.
    Please advise if there is any solution.
    Thank you.
    Goodday my friend,
    It's a know issue and will be fixed in upcoming update.
    Not all user are being affected. I had totally no reboots.
    It was already fixed in beta version say some forum users.
    But beta is offline due a problem in it.
    Hold on my friend till new beta update and or official update is coming.
    I hope for you and others it comes in the last week off december.
    Otherwise it should be january. please be patient and hold on.
    Everything will be okay.
    I'll take a look, thank you.
    Do you know if a solution will be provided for the official YouTube app? Thank you.
    If Google break it's self, i say it carefully... but i think the do it by purpose, cause it's android aosp and not device certified android, so not the official AndroidTV or certified Android like on a phone...
    But who knows, maby will google turn it back. Maby it's a google/android bug. That can also, cause a forum user say that Youtube was disappeared on his Formuler GTV. And the Formuler GTV has the official AndroidTV software and is certified!
    So it's possible that's it a mistake by google...
    ...we only can wait...
    I will try later the day to install youtube on my z11 and z12. (I deleted YouTube with adb app, cause i don't use it because the commercials)
    And i will try it and watch it the coming week if it installs and stays on my device.
    Ok thank you. Sadly my soundbar is just a basic one that doesn’t support dts or Atmos. Will be buying a new better one in the new year.
    But both my soundbar and tv have those ports so will try them and try to set up the remote so at least the formuler remote can control the sound and on/off for the tv.
    Thanks again
    If it has those both hdmi ports, the tv volume buttons works with your sounbar volume up and down.
    If you turn on hdmi-cec on your tv and you turn off the tv, the soundbar should also be turn off. I think your soundbar can react with hdmi cec.
    So if you go to bed. Push upper left button and tv and soundbar should be go off.
    I did switch it to Smarttube now before your answer. It works, lets hope it continues to do that! Yet again thanks for quick advice!:smiling_face:
    Good job my friend.
    Don't forget to go to smarttube settings, then information, and then switch on popup for new update!!
    I contacted someone from formuler for put the newest smarttube in market, but i was to quick. The newest smarttube is already in the formuler market.
    Ok thanks I’ll try setting it up again. My soundbar is connected via optical from soundbar direct to tv optical in connection. I’ll try and find a hdmi cable and connect from soundbar to tv hdmi and see if that works.
    First check if your soundbar has a hdmi in/(e)arc port.
    Then check if your tv have a hdmi 2.1 (e)arc port..
    If both yes.
    Plug in a good hdmi in the hdmi 2.1 (e)arc port and then in the hdmi-in port in your soundbar.
    If your soundbar supports dolby dts and atmos and thruehd then you need hdmi.
    With a optical cable you can max receive dolby 5.1.
    With hdmi connected by hdmi (e)arc and your soundbar supports dts, and dolby atmos then it works with passthrough.
    With a optical cable you don't get atmos, or dts etcetera cause opticial cable doesn't support it.
    Hdmi it does. So i hope your tv has hdmi (e)arc and your soundbar supports dolby atmos and dts etc.
    Then you see that you have a better sound then before.
    Here hdmi info for audio support:
    Google Search
    and We are back om the same problem! It worked a couple of times going into a VOD trailer, showing it on Youtube...Now we are back on looking at a trailer and it does not go back into MOL3 it is stuck in Youtube...If you force to close MOL3 it starts up with only sound...it takes a reboot/restart of Z12 for MOL3 to work again. Accept for trailers...
    Is it a bug? Does anyone else have this issue?! It doesn't do this on my 11 Pro MAX.
    Temporary fix:
    Remove smarttube from your box.
    Open mytvonline.
    Set watch trailers to smarttube.
    It opens formuler market.
    Install smarttube.
    And done. Now you can watch trailers with smartube. (If google due update that also didn't blocked)
    I did contact Formuler for newest package for the formuler market.
    and i hope they changed it in the update.
    Hi, I am having a problem with Mytvonline app on GTV
    With several IPTV playlists it only displays the first half of the channel groups
    Its not the case with mytvonline on my phone or windows apps, just the one on GTV
    Can anyone talk with or resolve this issue with Formuler team, would be grateful
    Tey first in mytvonline2 menu to make an backup on usb.
    Remove mytvonline2.
    Restart box.
    Install mytvonline2 from formuler market (green logo with white trolly)
    And restore from mytvonline2 the backup from the usb.
    If that not helps.
    Contact your provider.
    And ask him to delete all the countries in your package! Except the countries you watch.
    If you only watch at italy and usa, you can let your provider remove russia, france, belgium, asia, africa etcetera you know? What you don't watch, let it remove by provider!
    You have then a shorter list, it's loading much faster, faster epg updated etcetera.
    Give it a try my friend.
    When doing this, what should happen? Do I get a “normal” picture instead of reddish pictures, or will my picture become “real” HDR10 and having HDR effects?
    (Can’t try it yet, because I don’t own the Z12 at the moment. I want to know if this feature is possible)
    I changed in android settings from image adaptive to hdr10.
    I played with Kodi a Dolby Vision movie with Dolby Atmos.
    The movie play normal and gives the dolby atmos logo. NOT hdr logo, cause it's dolby vision hdr, but i forced it to hdr10.
    Z12 remote you connect with bluetooth so you can control your box.
    If you setup the remote with formuler remote app to your tv brand.
    You can control also your tv on and off with upper left corner button.
    And if you hold left upper button in stb/tv 2 seconds. Remote blinking and you can control tv for a part.
    Hold stb/tv button in 2 seconds, led on remote blinks again and it's set to bluetooth again.
    But tree devices with one remote?
    If soundbar is plugged in your hdmi (e)arc you can control it with tv buttons on the side if you setup remote to your tv brand.
    It would be great if Formuler could quickly release an update for the Z11 Pro, as YouTube is one of the most widely used apps across all platforms. It's a real shame that a quick solution hasn't been found to a problem that has been going on for several months, as I think it's preventing a lot of people from returning their devices after purchase because of this issue.
    SmartTube is a good solution, but it's not suitable for everyone, and I can understand that.
    For my part, I switched from the Z11 Pro to the Z12 Ultra solely for this reason... €200 is a lot to pay for YouTube, but it's an app I use for several hours every day, so it's essential for me.
    I didn't need the Z12 Ultra, I could have stuck with the Z11 Pro, which suited me perfectly, but circumstances forced me to change.
    I still hope that Formuler will release an update soon to fix this problem, so I can take my Z11 out of its box and use it 🙏🏻
    First: it's not a Formuler problem. A forced update what GOOGLE DID, did youtube to be broken.
    https://github.com/reisxd/TizenTubeCobalt/releases/download/v1.0.5/cobalt-arm.apk
    Try this! exactly the same interface as youtube!!
    Or SmartTube: a simply version of youtube. https://github.com/yuliskov/Smart…tube_stable.apk
    Try them both, and see which one you keep.
    I will try today, i think if you won't want dolby vision, and set it to hdr10 it get normal hdr picture. Cause hdr10 is maby not in the movie.
    Should work i think. Test it later.
    Lucky13 - it didn't work. mediabrowser not recongizing in protonvpn apk.
    I tested it on my Z12 my friend. And it worked with mediabrowser??
    Put it directly in usb port on device! Not via a hub!
    Has the mediabrower the right rights? The usb is ntfs formatted?
    Try from playstore install "file manager plus" and give it the rights if it ask.
    You can also use the "storage analyse" and remove cache files! to free more space.
    It was my pleasure my friend.
    But i advice: use Netflix always from your smart tv!!!
    Not from the box! Cause you have only ugly SD format and no HD on the box.
    Use it only on your box in case if you have a tv that is so old, that it hasn't netflix on it!
    The tv support almost always hd and 4k. And the most tv's from the last years supports Hd, 4K, Dolby Atmos and Dolby Vison.
    Simplest waybis to install it via google play store.
    alternative with usb:
    Your usb stick needs te be ntfs formatted first for sure on a pc.
    Proton vpn you can download from playstore and or
    https://github.com/ProtonVPN/android-app/releases/download/5.14.76.0/ProtonVPN-5.14.76.0.605147600.-production-vanilla-direct-release.apk
    Put downloaded apk on usb.
    Put usb in box and open mediabrowser, usb, and then the protonvpn apk.
    Maby you go try to Formuler remote app.
    Then choos the colorer buttons.
    Maby i stands there. I had also one time i cloudn't find the installed app on the gtv.
    But in the formuler remote app you can add an app to an colored button.
    Then it saw it and it worked out.
    Hope for you too. Netflix is very secured and block al the ways.
    Please share the apk for user who want it on there box.
    (I don't, i use it on my tv, but some users like it to have it on there box. (Why I don't understand cause you got only the lowest quality sd)
    And smart tv's exists about 15+ years or so
    Thanks for the qiuck feedback...
    It turns out MOL3 suddenly appeared for update after 2 restarts and now the issue with Youtube is solved for some reason :smiling_face:
    Never used SmartTube so I don't know how good that one is in this region...will give it a try!
    Otherwise you can use TizenTube instead of smarttube.
    That's exactly youtube, but without commercials.
    You can use it normally, but NOT in mytvonline3!!
    Actually I own a Formular Z11 BT edition. Besides the nVidia Shield it's one of the only Android boxes I know who's capable of playing back Dolby True HD and more importantly Dolby Atmos on a TrueHD track.
    My Tizen Based Loewe Stellar TV doesn't Support Dolby Vision. I have a lot of DV only movies on my NAS. On the Z11 Reddish picture is the only thing I can get. Using an Apple TV this is possible, but TrueHD isn't supported on that device.
    Does somebody know this Z12 has the feature to convert Dolby Atmos to HDR10?
    Only what i know is go to android settings. (Cogwheel)
    Device Preference
    Image and sound
    Hdr output mode
    Change from adaptive to hdr10.
    or hlg or off in last case.
    Let me know if it works or not.
    Goodday my friend
    I had problems with Z12 MOL3 when looking at a trailer it did not go back from Youtube to MOL3 it got stuck. So finally I did a factory reset as I could not see the problem at friends Z12...Now I cannot find MOL3 in apps or Market place? How to I get it?!
    Strange my friend, when i did factory reset with my Z12 the software update did install firmware and mytvonline3
    Do software update. Try it.
    Oh and if you start mytvonline3, select in settings smarttube for trailers.
    If you do that it sends you to Formuler maker smarttube.
    Install that on and you can use it for trailers.
    Let me/us know how is was going.
    Keep it on your raspberry pi. Switch sd cards for other things on your pi.
    I have reached you out already for help with apps, but no answer.
    Maby the apps are just for mobiles only.
    But if you give me the app names, maby i can help find them for you.
    We all help each other right?
    I am going to answer my own question - It looks like Formuler USB-C Hub is probably I need. Tried network storage linking Z mini and my desktop it couldn't commuicate.
    You can link windows samba shares to your nas. I have a raspberry pi 5 with openmediavault nas software.
    Vpn you can install via playstore.
    And or remove some apps first. And then install your vpn.
    Which vpn you have? Most times you can download the right version (AndroidTV) from the website of the vpn provider via pc. And sideload it.
    And extra info: if you select on the right side of the screen your subtitle language. Please remove the other languages to the left side of the screen. So only your homecountry language sub on the right.
    "It can" gives a subtitle error if you let all countries on right side.
    Read it on forum onetime. Just saying.
    Hello, I'm also having the same problem for several days. I've tried everything: factory reset, VPN in various countries, factory reset again, changing different connection types, and nothing works. I also installed TizenTube, which works, but it's not compatible with MYTV3. I think Formuler is losing credibility. Previously, it was a problem with TeamViewer starting with model 11, and it still doesn't work. Now it's YouTube. I also think Formuler should pay more attention to this type of important application and keep it updated to avoid these kinds of issues. If you happen to have a solution, please share it. I have an open store and I'm losing customers to these boxes.
    In formuler market you can find smarttube.
    The one from formuler market app (green logo and white trolly) is functional with trailers in mytvonline3.
    If you download it from officia website and sidelaod it, it works, but not via mytvonline3... strange, but true.
    Mytvonline3 goes to Formuler market to the smarttube app.
    Why it don't just open the app? I don't know.
    For trailers via mytvonline3, delete smarttube and download it from formuler market. Then it works.
    I’ve seen a few people mention similar behavior, so you’re definitely not alone. It sounds like the Wi-Fi module isn’t reinitializing properly during a soft reboot. A full power cycle forces the hardware to reset, which is why it works again after unplugging. If you haven’t already, try checking for the latest firmware and clearing the network settings before reconnecting. It may also help to test with a different power adapter just in case the box isn’t getting stable power during restart. Hopefully others can test on their devices too so we can see if this is a wider issue.
    Wifi and ethernet problems will be fixed in next update. Some users have, the most users not.
    Please be patience and update will come.
    Hi all my Z11p has stopped working. All I'm getting is the word formuler and the four dots moving up and down.
    External Content m.youtube.com
    iIf there are no updates by the end of the month, I can therefore conclude that the era is over. When I see all the bugs and the lack of response from the staff, I think, what's the point of complaining? Nothing ever changes. Today it was Wi-Fi and Ethernet disconnections, why? We don't know? Yet everything works fine on my other devices... Anyway, just another bug. 200 bucks, guys, what a regret this purchase :unamused_face:
    I understand you are not happy. But pc's, cars, tv's, tv boxes, software etc also need updates.
    You can send it back, and buy it a half year or year later again, if you can't wait for the updates. They can bring an update online fast, but then maby other problems. It's a small company, better wait what longer and good update with many fixes and improments then every week one update with just 1 fix.
    Christmas is also coming so. Make your choice. wait for updates. They are working hard on each problem. The must reproduce the user problem. Sometimes it happens in one time and other problems to reproduce the can't. We have the same box. I don't have ethernet problems. Some have it.
    In you can't wait, send it back...
    ...buy it a year later when it had some updates. But everything will be okay my friend. Just have some patience.
