MT7610U is not on the list.
Thanks for the help I will return it
We are a family owned and operated business.
Did you check if the chipset is compatible?
When I asked at the store the guy said that was compatible with one of the list but I can´t remember which one was...
Hi maybe someone could help me
I have a TP-LINK ARCHER T2U and a formuler z7+ and I can´t see 5gh networks only 2 G
What I´m doing wrong.
seanns32 thanks again for the help.
I will try later the full manual factory reset.
I bought it online from a shop in Sweden, I live in Norway so I think it´s ok to return it.
If it doesn´t work I will contact them to return it.
Hi seanns32 thanks for the help.
to get the main screen it takes more than 5 to 10 min, I can short it out if I press 3 or 4 times channel up on the remote. (I think I saw it in this forum).
Yes nothing happens if I press the play. Some of them have a red shaded background and when I press OK starts playing just for some seconds and then I got an error message.
My IPTV provider confirmed that the catchup is functional.
Current Firmware Version: V1.2.28
Current IPTV Version: V1.9.43
I´m a new user. Just got my Z7+ this Monday and when I restart or plug the box on it takes a lot of time to run and get the main screen. It loop between the main logo and the android logo. I have all the updates on just did a factory reset and nothing as changed.
My tv provider have the possibility to watch programs till 3 days back. I select the channel that have that option in the mytvonline I select epg go to the time / program that I want to watch select ok and don´t work. I have the the red play button icon on the channel logo but I don´t have the clock icon on the program in the timeline.
the rest works fine.
Thanks in advance
D
